Arduino rs485 Modbus
Hi everybody,
i am looking for somebody, who help me with my problems or give me some advice.
I need to make code from arduino modbus master as Reader data via rs485 from multiple arduino modbus Slave as writer data (measure value and write/hold data in register).
So i can not found some example code which will be working. Would anyone help me or provide functional background materials for the study?
Thak you very much
The best regadrs
Hynek
A good place to start would be the ArduinoModbus Library... it comes with examples - ArduinoModbus - Arduino Reference
This is only true for newer ARM based Arduinos. The AVR are less targeted by the library, it simply need too much memory for this MCUs.
There is no clear reommendation for the AVR Arduinos but there are dozens of thread in the forum to keep you started.
I created code for modbus master and slave. Arduino slave "measure" data and write data in register (holding register). After than arduino master read data via modbus (connected rs485) ... I create register for 60 value but the master can read only 30 value. Here are the code.
I make some mistake ???
Master :
//Arduino modbus master
//Knihovny
#include <ModbusMaster.h> //Library for using ModbusMaster
#define MAX485_DE 3
#define MAX485_RE_NEG 2
ModbusMaster node; //object node for class ModbusMaster
int pocet = 59; // pocet registru k vycteni
int8_t j, result;
int16_t data[59];
void preTransmission() { //Function for setting stste of Pins DE & RE of RS-485
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
void postTransmission() {
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
Serial.println("CIRCUIT DIGEST");
Serial.println("Arduino");
Serial.println("Modbus Master");
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
Serial.begin(115200); //Baud Rate as 115200
node.begin(1, Serial); //Slave ID as 1
node.preTransmission(preTransmission); //Callback for configuring RS-485 Transreceiver correctly
node.postTransmission(postTransmission);
Serial.println("Start");
void loop(){
uint8_t j, result;
int16_t data[pocet];
result = node.readHoldingRegisters(0, pocet);
Serial.print("Co tam mam?");
if (result == node.ku8MBSuccess)
for (j = 0; j < pocet; j++)
data[j] = node.getResponseBuffer(j);
Serial.print("Adresa registru je: ");
Serial.print(40000+j);
Serial.print("Hodnota je: ");
Serial.print(data[j]);
Serial.println("--- --- ---");
delay(2000); //delay 2s
Slave:
//Arduino nano RS-485 Modbus Slave
//Knihovny
#include<ModbusRtu.h> //Library for using Modbus in Arduino
//promenne
Modbus bus; //Define Object bus for class modbus
int16_t modbus_array[] = {
11,1,0,2,0,3,0,4,0,5,0,6,0,7,0,8,0,9,0,11, //
22,1,0,2,0,3,0,4,0,5,0,6,0,7,0,8,0,9,0,22, //
33,1,0,2,0,3,0,4,0,5,0,6,0,7,0,8,0,9,0,33, //
}; //Array initilized with three 0 values
int p = (sizeof(modbus_array)/sizeof(modbus_array[0]));
boolean start = true;
Serial.println("RS-485 Modbus"); //Welcome Message
Serial.println("Arduino Slave");
bus = Modbus(1,1,4); //Modbus slave ID as 1 and 1 connected via RS-485 and 4 connected to DE & RE pin of RS-485 Module
bus.begin(115200); //Modbus slave baudrate at 9600
Serial.println("Velikost array je: ");
Serial.println((sizeof(modbus_array)/sizeof(modbus_array[0])));
Serial.println("Velikost array pro podmínku je: ");
Serial.println(p);
bus.poll(modbus_array,sizeof(modbus_array)/sizeof(modbus_array[0])); //Used to receive or write value from Master
//výpis dat
for (int i = 0; i < p ; i++ ){ //Výpis dat
//Serial.println();
Serial.print(40000+i);
Serial.print(modbus_array*);*
  • Serial.println();*
  • //delay(1000); //delay 1s*
    _ */_
Edit your post and insert code tags!
Sorry about it, i apologize.
Master:
//Knihovny
#define MAX485_DE      3
int8_t j, result;
int16_t data[59];
void loop(){
  uint8_t j, result;
Slave:
//Knihovny
//promenne
  Serial.println(p);
   //výpis dat
      //Serial.println();
      Serial.print(modbus_array);
Bad idea. You tell the ModbusMaster library that it can exclusively use the Serial interface for the Modbus traffic and a few lines later you write something to the same interface. The opposite side won't expect other stuff to happen on that line.
Use lower baudrates than 115200 to start. If everything works you may increase the baudrate.
