Hey gyys, I have a problem! my Adruino is not running, though I have javaRE on my machine. When I checked the run.bat file for errors, It gav e me.... @echo off
REM --- if you're running out of memory, change the 128m REM --- (which means 128 megabytes) to something higher.
set SAVEDCP=%CLASSPATH% set SAVEDPATH=%PATH% set JAVA_HOME="java\bin"
if %JAVA_HOME% == "" GOTO Error
set CLASSPATH=java\lib\rt.jar;lib;lib\build;lib\pde.jar;lib\antlr.jar;lib\RXTXcomm.jar;lib\oro.jar;lib\registry.jar;lib\mrj.jar set PATH=java\bin;lib;%PATH%
REM start javaw -ms128m -mx128m processing.app.Base %JAVA_HOME%\java processing.app.Base
set CLASSPATH=%SAVEDCP% set PATH=%SAVEDPATH%
GOTO End
:Error echo *** Error: cannot execute Arduino echo *** Reason: lacking the directory where to find Java in your computer echo *** echo *** Fix: Edit run.bat and add the JAVA_HOME directory echo *** at the 'set JAVA_HOME=""' line echo *** echo *** then call the batch file run.bat in order to execute Arduino
:End Pause echo Bye. ............................................ How do you fix that, Any ideassss.... Thanks a LOT M :'(
