Arduino RX LED does not blink when nRF24L01+ connects and code is uploaded.
Hello,
As the title suggests, the RX LED on my arduino does not blink whenever i fully connected all 7 ports of nRF24L01+ into the respective pins. However, whenever i pull out one of the pins, ( whether CE, CSN,MOSI,SCK,MISO ), the Serial monitor would then proceed to print the array that i wrote in the code, but clearly wrong data (See the code below).
It was working fine previously, however, once i started to solder the wires on to the arduino itself, this problem occured. I unsoldered everything and now its not working anymore.
I'm not sure if i had short circuit the ports, but just by visually looking, i'm quite sure they're not.
Since there should not be any problem with my code because it worked before, also i did a simple blink test on all my ports to make sure all pins are not shorted.
How else can i troubleshoot this issue?
Edit: The board only has issues with the nRF24L01+ (I tried using another nRF24L01+, same issue), other codes works fine. This is what baffles me.
#include <Adafruit_PWMServoDriver.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Wire.h>
//Defining nrF2401n+ --------------------------------------
RF24 radio(8, 7); // CE, CSN
const byte address[6] = "00001";
//Defining PCA 9685 --------------------------------------------
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN  160
#define SERVOMAX  335
int x_pos;
int y_pos;
int ForkUpButton;
int ForkDownButton;
int ClawGrabButton;
int ClawReleaseButton;
int dataSend[6];
int Left = 0;
int Right = 0;
// motor one ----------------------------------
int enA = 6;
int in1 = A0;
int in2 = A1;
// motor two ---------------------------------
int enB = 5;
int in3 = A2;
int in4 = A3;
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.setPALevel(RF24_PA_MIN);
  radio.startListening();
  pwm.begin();
  pwm.setPWMFreq(60);
  delay(10);
  if (radio.available())
    radio.read(&dataSend, sizeof(dataSend));
    Serial.println("Available");
    Serial.println(dataSend[0]);
    Serial.println(dataSend[1]);
    Serial.println(dataSend[2]);
    Serial.println(dataSend[3]);
    Serial.println(dataSend[4]);
    ForkUpButton = dataSend[0];
    ForkDownButton = dataSend[1];
    ClawGrabButton = dataSend[2];
    x_pos = dataSend[3];
    y_pos = dataSend[4];
    // ForkLift Mechanism -----------------------------------
    if(ForkUpButton == 1)
      pwm.setPWM(6, 0, 150);
    if(ForkDownButton == 1)
      pwm.setPWM(6, 0, 600);
    else if(ForkUpButton == 0 && ForkDownButton == 0)
      pwm.setPWM(6, 0, 4096);
   // Claw Mechanism ----------------------------------
    if(ClawGrabButton == 1)
      pwm.setPWM(7, 0, 160);
    else if(ClawGrabButton == 0)
      pwm.setPWM(7, 0, 380); //strength grip
   //RC Car Codes ------------------------------------
    if (y_pos < 470)
        digitalWrite(in1, HIGH);
        digitalWrite(in2, LOW);
        digitalWrite(in3, LOW);
        digitalWrite(in4, HIGH);
        Left = map(y_pos, 470, 0, 0, 255);
        Right = map(y_pos, 470, 0, 0, 255);
    else if (y_pos > 550)
        digitalWrite(in1, LOW);
        digitalWrite(in2, HIGH);
        digitalWrite(in3, HIGH);
        digitalWrite(in4, LOW);
        Left = map(y_pos, 550, 1023, 0, 255);
        Right = map(y_pos, 550, 1023, 0, 255);
        Left = 0;
        Right = 0;
    if (x_pos < 470)
      int xMap = map(x_pos, 470, 0, 0, 255);
      Left = Left - xMap;
      Right = Right + xMap;
      if (Left < 0)
        Left = 0;
      if (Right > 255)
        Right = 255;
    if (x_pos > 550)
      int xMap = map(x_pos, 550, 1023, 0, 255);
      Left = Left + xMap;
      Right = Right - xMap;
      if (Left > 255)
        Left = 255;
      if (Right < 0)
        Right = 0;
    if (Right < 75)
      Right = 0;
    if (Left < 75)
      Left = 0;
    analogWrite(enA, Left);
    analogWrite(enB, Right);
    delay(50);
