Arduino RX not working
I am trying to read an SMS message from a GSM modem .
My arduino TX and RX are connected to a MAX232 IC and from the IC another 2 wires goes to the RS232 cable of the Modem.
I am capable of sending a string to the modem. I even sent an SMS from the arduino. and I also see the TX led flashing when sending the strings
When I try to read the responses from the modem I get nothing because the serial interrupt is not being triggered
When I disconnect the RX pin of the arduino that goes to the MAX232 it works . When i send something through the serial port it works, the RX led blinks and the prints me back the string as supposed
any ideas are appreceated
Thanks
You don't mention a GND connection. That is usually essential as well as Rx and Tx.
...R
Yes I used common ground from the RS232 cable
I assume that if the TX worked with that ground the RX should too
Post your code.
And please use the code button </> so your code looks like this and is easy to copy to a text editor
…R
char receivedString[100]; // received string
char sensorString[100]; // received string
char count; // string counter
float time_counter=0;
float seconds;
Timer_Initialise();
serialBegin();
interrupt_Initialise();
sei();
pinMode(13,OUTPUT);
serialPrint(“at+cmgf=1\r”);
delay(5000);
void serialBegin(void)
int baudrate=103; // 9600
UCSR0B = (1 << RXEN0) | (1 << TXEN0); // Turn on the transmission and reception circuitry
UCSR0C = (3 << UCSZ00) | (1 << USBS0); // Use 8-bit character frame
UBRR0H = (baudrate>>8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
UBRR0L = baudrate; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
UCSR0B |= (1 << RXCIE0); // enable RX interrupt
void Timer_Initialise(void){
// Divide clock Freq by 64
// The timer is cleared after the compare (1mS)
TCCR1B=(1<<WGM12)|(1<<CS11)|(1<<CS10);
OCR1A=250; // (1/f)PS = 4uS 4uS250 = 1mS delay without pausing the programm
TIMSK1|=(1<<OCIE1A); //Enable the Output Compare A interrupt
void interrupt_Initialise(void){
sei();
EIMSK = 1<<INT0; // enable external interrupt
EICRA = 1<<ISC01 | 1<<ISC00; // detect rising edge
void serialPrint(char *x)
while(*x != 0) //search for null terminator
UDR0=*x; // transmit a character
x++; // look the next character
delay(100);
void sendSMS(void)
serialPrint(“at+cmgs= “);
serialPrint(””+35679852525" \r");
serialPrint(“hello”);
UDR0=26; //Ctrl+Z
delay(10000);
ISR(USART_RX_vect) // Read String
digitalWrite(13,HIGH);
receivedString[count]=UDR0;
delay(100);
if(receivedString[count]==’\n’)
receivedString[count-1]=0;
count=0;
UDR0=0;
if (strcmp(“OK”, receivedString) == 0)
serialPrint(“babababa\n”);
delay(5000);
else{
count++;
ISR (TIMER1_COMPA_vect)
time_counter++; // every 1mS
ISR(INT0_vect)
seconds=(time_counter/1000)+(TCNT1*0.000004);
sprintf(sensorString,"%f",seconds);
time_counter=0;
You obviously did not read all of Reply #3.
...R
I did’t got your point, using the >< and pasting directly would not make a difference for you. it the same code after all
bastjan:
Perhaps. But I suspect you did not put smileys in your code.
And the way you have it I can’t click SELECT and copy it to my text editor. Help us to help you. Read How to use the Forum
Frankly, I wonder why I even wasted the time to write this.
…R
Please read #7 below:
http://forum.arduino.cc/index.php/topic,148850.0.html
