arduino/sanguino with ATmega644 (non P)
since I've got an ATmega644 (non P) lying around, I am wondering if it cannot be used in an sanguino.
I flashed it with the bootloader that comes with the sanguino software, set the fuses but when I now try to upload a sketch with the arduino software I get an error:
avrdude: Expected signature for ATMEGA644P is 1E 96 0A
Double check chip, or use -F to override this check.
Can someone please point me to where I could either add the "-F" option or change the chip to ATMEGA644?
thanks
In the boards.txt file, change
sanguino.build.mcu=atmega644p
to
everything else can remain the same
actually I replaced every occurance of atmega644p with atmega644 before, but i DIDN'T RESTART the arduino software, so it didn't work and I changed it back.
But after a restart, everything is working fine, thanks @mem
What are the dimensions of a atmega644P'U DIP40 in milimeters ?
You mean, as in 40 pin part, 0.6" wide, 0.1" lead spacing?
