Arduino SD Card - Error while opening file. (Creating a unique file)
Hello,
I am facing problems with the code below.
Since I developing code for a bigger project, the code is split into functions.
The program creates a new unique file every time I reboot my Arduino, very helpful when it's a data logger.
What's the problem?
It successfully creates a new unique file. But when opening that file crashes(myFile = 0)
check main.ino
Psuedo Code
  //Create a file with new name
    if (!loadSDFile()) {
    Serial.println("Failed to create file");
    while(1);
     else {
    Serial.println("File name created!");
  myFile = SD.open("DLOG.txt", FILE_WRITE);
  if (myFile) {
    "worked"
    "didn't work"
What have I tried, so far?
I tried writing the code in a separate environment. The weird thing is works! Have no idea how and why?
Check - SD_MODULE.ino
Equipment
Arduino Nano
MicroSD Card
Please help.
If there's any other suggestion for my code. Please do tell.
Check the two files in the attachment.
main.ino (15.4 KB)
SD_MODULE.ino (3.62 KB)
