I've recently purchased a Virtuabotix SD Card Reader/Writer and for some reason it doesn't write to files.
It can't be the SD card because the sketch CardInfo works properly on it (even though it is 8 gb).
Everything from the Serial Monitor standpoint functions correctly. It prints out "Initializing SD Card...initialization done" then "test.txt exists" then "writing to test.txt...done"
Even though I created the text file on Notepad manually, I know that it is able to recognize the file because it printed out "writing to test.txt"
But when I plug the SD Card into the computer, I don't see anything on the file test.txt .
#include <SD.h>
#include <SPI.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
if (SD.exists("test.txt")) {
Serial.println("test.txt exists.");
Serial.println("test.txt doesn't exist.");
myFile = SD.open("test.txt", FILE_WRITE);
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
Serial.println("done.");
myFile.close();
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
What could possibly be wrong with my file writing functions? I even used multiple types of print functions in hopes one would work.
Hopefully somebody more skilled than I can work this out.
Thanks,
Nathan
Edit: I've figured out that the problem centers around the line myFile.println("testing 1, 2, 3.");
How do you properly output data onto the sd card w/o causing errors
