Arduino send data to google docs
Hello,
I created a form on google docs and has the following Url adding data to a spreadsheet using this form.
https://docs.google.com/forms/d/1VUQJmQfwn5EWIXd0SB-YV5M_SHXztAPRQtmZs3kCHhk/formResponse?ifq&entry.345996422=teste&entry.2062261769=teste&submit=Submit
I searched the internet and found some code to use the ethernet shield to send the information to google docs, but I have difficulty adjusting the link above for the method post below
char formkey[] = "1VUQJmQfwn5EWIXd0SB-YV5M_SHXztAPRQtmZs3kCHhk";
#include <UIPEthernet.h>
EthernetClient client;
signed long next;
  uint8_t mac[6] = {0x00,0x01,0x02,0x03,0x04,0x05};
  Ethernet.begin(mac);
  Serial.print("localIP: ");
  Serial.println(Ethernet.localIP());
  Serial.print("subnetMask: ");
  Serial.println(Ethernet.subnetMask());
  Serial.print("gatewayIP: ");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("dnsServerIP: ");
  Serial.println(Ethernet.dnsServerIP());
  next = 0;
  String data;
  data+="";
  data+="entry.345996422=";
  data+=10;
  data+="&entry.2062261769=";
  data+=20;
  data+="&submit=Submit";
  if (((signed long)(millis() - next)) > 0)
      next = millis() + 5000;
      Serial.println("Client connect");
    client.println("Host: docs.google.com");
    client.print("POST /forms/d/");
    client.print(formkey);
    client.println("/formResponse?ifq&");
    ///  client.println("Content-Type: application/x-www-form-urlencoded");
    ///  client.print("Content-Length: ");
    ///  client.println(data.length());
    ///client.println();
    client.print(data);
    client.println("&submit=Submit");
    client.println("Connection: close");
    Serial.println("Host: docs.google.com");
    Serial.print("POST /forms/d/");
    Serial.print(formkey);
    Serial.println("/formResponse?ifq&");
    Serial.println("&submit=Submit");
    ///Serial.println("Content-Type: application/x-www-form-urlencoded");
 ///   Serial.println("Connection: close");
  ///  Serial.print("Content-Length: ");
   /// Serial.println(data.length());
  ///  Serial.println();
    Serial.print(data);
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
  delay(10000);
      // replace hostname with name of machine running tcpserver.pl
//      if (client.connect("server.local",5000))
      if (client.connect(IPAddress(192,168,1,10),5000))
          Serial.println("Client connected");
          client.println("DATA from Client");
          while(client.available()==0)
              if (next - millis() < 0)
                goto close;
          int size;
          while((size = client.available()) > 0)
              uint8_t* msg = (uint8_t*)malloc(size);
              size = client.read(msg,size);
              Serial.write(msg,size);
              free(msg);
close:
          //disconnect client
          Serial.println("Client disconnect");
          client.stop();
        Serial.println("Client connect failed");
The ethernet adapter connected successfully and I can see the ip’s
