arduino send data to web page using esp 01 . Please help , noob here
Jul 26, 2018, 07:50 am
Help me anyone here , Ip address wasnt shown in this code:
I got a code I used here :
#include<SoftwareSerial.h>
SoftwareSerial comm(12,13); //setting Tx and Rx pins
String server=""; //variable for sending data to webpage
boolean No_IP=false; //variable to check for ip Address
String IP=""; //variable to store ip Address
char temp1='0';
int a=0;
int b=0;
String str1="
I am Arduino
"; //String to display on webpage
String str2="
Data Received Successfully.....
"; //another string to display on webpage
comm.begin(115200);
wifi_init();
Serial.println("System Ready..");
b=0;
Serial.println("Refresh Page");
while(b<1000)
b++;
while(comm.available())
if(comm.find("0,CONNECT"))
Serial.println("Starting");
sendToServer();
Serial.println("Finished");
delay(1);
void findIp(int time1) //check for the availability of IP Address
int time2=millis();
while(time2+time1>millis())
while(comm.available()>0)
if(comm.find("IP has been read"))
No_IP=true;
void showIP()//Display the IP Address
IP = "";
char ch = 0;
while(1)
comm.println("AT+CIFSR");
if(comm.find("STAIP,"))
Serial.print("IP Address:");
ch=comm.read();
if(ch=='+')
IP+=ch;
if(ch=='+')
if(ch=='+')
Serial.print(IP);
Serial.print("Port:");
Serial.println(80);
void establishConnection(String command, int timeOut) //Define the process for sending AT commands to module
int q=0;
while(1)
Serial.println(command);
comm.println(command);
if(comm.find("OK"))
q=8;
delay(timeOut);
if(q>5)
q++;
if(q==8)
Serial.println("OK");
Serial.println("Error");
void wifi_init() //send AT commands to module
establishConnection("AT",100);
establishConnection("AT+CWMODE=3",500);
establishConnection("AT+CWQAP",500);
establishConnection("AT+RST",5000);
findIp(500);
if(!No_IP)
Serial.println("Connecting Wifi....");
establishConnection("AT+CWJAP="CHINA","gumiho24"",7000); //provide your WiFi username and password here
Serial.println("Wifi Connected");
showIP();
establishConnection("AT+CIPMUX=1",1000);
establishConnection("AT+CIPSERVER=1,80",1000);
void sendData(String server1)//send data to module
int p=0;
while(1)
unsigned int l=server1.length();
Serial.print("AT+CIPSEND=0,");
comm.print("AT+CIPSEND=0,");
Serial.println(l+2);
comm.println(l+2);
Serial.println(server1);
comm.println(server1);
Serial.print(Serial.read());
if(comm.find("OK"))
p=11;
if(p==11)
delay(100);
void sendToServer()//send data to webpage
server = "
Welcome to Data Receiving from Arduino
sendData(server);
server=str1;
server+=str2;
sendData(server);
delay(5000);
comm.println("AT+CIPCLOSE=0");
///OUTPUT
AT
AT
OK
AT+CWMODE=3
AT+CWMODE=3
OK
AT+CWQAP
AT+CWQAP
OK
AT+RST
AT+RST
OK
Connecting Wifi....
OK
Wifi Connected
** BUT I couldnt get the ip address of my the wifi**
No sure where you got that code from but it’s not great...
If you read French (or use google translate) may be you can get something out of a small tutorial I wrote on using ESP-01
Using software serial at 115200 bauds is also likely going to fail you if your uno is busy doing other stuff as well. Use a mega with more than one hardware serial or go for a MKR1000 type of Wemos D1 where you have WiFi embedded directly at higher level
