Arduino send email error in documentation
Hello,
There is a error in code snippet 1 at https://playground.arduino.cc/Code/Email
The code to send “AUTH LOGIN” command is missing in code snippet 1 at above link. While executing the code, I got a " 500 - unrecognized command" from a smtp server.
The correct working code is below:
Email client sketch for IDE v1.0.5 and w5100/w5200
Posted 7 May 2015 by SurferTim
#include <SPI.h>
#include <Ethernet.h>
// this must be unique
byte mac = { 0x90, 0xA2, 0xDA, 0x00, 0x59, 0x67 };
// change network settings to yours
IPAddress ip( 192, 168, 2, 2 );
IPAddress gateway( 192, 168, 2, 1 );
IPAddress subnet( 255, 255, 255, 0 );
// Server is something as smtpout.secureserver.net
char server = “Your smtp server address”;
int port = 25;
EthernetClient client;
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
Ethernet.begin(mac, ip, gateway, gateway, subnet);
delay(2000);
Serial.println(F(“Ready. Press ‘e’ to send.”));
byte inChar;
inChar = Serial.read();
if(inChar == ‘e’)
if(sendEmail()) Serial.println(F(“Email sent”));
else Serial.println(F(“Email failed”));
byte sendEmail()
byte thisByte = 0;
byte respCode;
if(client.connect(server,port) == 1) {
Serial.println(F(“connected”));
Serial.println(F(“connection failed”));
return 0;
if(!eRcv()) return 0;
Serial.println(F(“Sending hello”));
// replace 1.2.3.4 with your Arduino’s ip
client.println(“EHLO 1.2.3.4”);
Serial.println(F(“Sending auth login”));
client.println(“AUTH LOGIN”);
Serial.println(F(“Sending User”));
// Change to your base64 encoded username of sender’s email address
client.println(“Your base64 encoded sender’s email address/username”);
Serial.println(F(“Sending Password”));
// change to your base64 encoded password of sender’s email address.
client.println(“Your base64 encoded sender’s password”);
// change to your email address (sender)
Serial.println(F(“Sending From”));
// Enter appropriate email address.
client.println(“MAIL From: sender@somedomain.com”);
// change to recipient address
Serial.println(F(“Sending To”));
client.println(“RCPT To: receiver@somedomain.com”);
Serial.println(F(“Sending DATA”));
client.println(“DATA”);
Serial.println(F(“Sending email”));
//Enter appropriate email address.
client.println(“From: Me sender@somedomain.com”);
// change to your address . Enter appropriate email address.
client.println(“To: Nobody receiver@somedomain.com”);
client.println(“Subject: Arduino email test\r\n”);
client.println(“This is from my Arduino!”);
client.println(".");
Serial.println(F(“Sending QUIT”));
client.println(“QUIT”);
client.stop();
Serial.println(F(“disconnected”));
return 1;
byte eRcv()
byte respCode;
byte thisByte;
int loopCount = 0;
while(!client.available()) {
delay(1);
loopCount++;
// if nothing received for 10 seconds, timeout
if(loopCount > 10000) {
client.stop();
Serial.println(F("\r\nTimeout"));
return 0;
respCode = client.peek();
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
if(respCode >= ‘4’)
efail();
return 0;
return 1;
void efail()
byte thisByte = 0;
int loopCount = 0;
client.println(F(“QUIT”));
delay(1);
loopCount++;
client.stop();
return;
client.stop();
Please correct the above page in your documentation.
Thanks!
I don't know what you are talking about. From the code in the playground (for SMTP2GO section):
  Serial.println(F("Sending auth login"));
  client.println("auth login");
  Serial.println(F("Sending User"));
  client.println("xxxx");
  Serial.println(F("Sending Password"));
  client.println("yyyy");
The first example is for those who do not need auth login.
