I don't find any example who works to send email with arduino and w5100 eth shield.
I tried with gmail account , tried with yahoo account but nothing, it doesn't work.
Anybody has a right code for this?
Many thanks in advance.
Did you try this?
http://playground.arduino.cc/Code/Email
You may have problems with it also. It sends email like an email server sends to another email server. The problem may be your email will be rejected because your ip address is not in a commercial subnet. If your account with your ISP is a residential type and your IP is issued by dhcp, then it will probably be rejected by many public email servers like Gmail and Yahoo.
Since the ethernet library does not support SSL or TLS, you can't send email to either of those services as a client.
Thanks a lot.
I tried that.
The problem is like you said , i was rejected by gmail server.My ip is not a commercial ip but i use a static ip after my provider.
Thanks again.
Anybody other sugestion?
I don't want to make my one email server.
If it rejected your email from your ip, don't bother setting up your own email server with the same or similar ip. It will be rejected also.
Check with your ISP tech support. Explain your challenge. Tell them you can't use SSL or TLS due to memory restrictions, and see if they have an alternative plan for you. Maybe they can open their email server to take port 25 relay email from your ip.
