Arduino Sending ASCII commands to programmable power supply
Hello guys,
I am working in a project where I would need to control a Programmable power supply with my Arduino DUE.
The programmable power supply is connected with an RS232 interface so I bought the UART to rs232 module for my arduino.
I made sure all the connections are properly connected and the voltages are at the right level.
When I try to send commands to the power supply nothing happens,
my code is:
bool once = false;
pinMode(22,OUTPUT);
Serial1.begin(2400);
void loop() // run over and over
digitalWrite(22, LOW);
if (once == false) {
onceloop();
void onceloop(){
if (Serial1.available()){
Serial1.write("SV 5");
Serial.print("connected");
once = true;}
return ;
When doing Serial1.write I have tried to send a string and it doesn't work. I don't know how to send Ascii commands.
I also tried doing
Serial1.write(0x56)
Serial1.write(0x74) etc...
which are the hexadecimal commands but nothing happens.
Anyone has any idea?
The link of the commands for the power supply is:
https://www.gwinstek.com/en-GB/products/downloadSeriesDownNew/7332/1431
I used it with my raspberry pi and I managed to do the commands in python but I cannot figure out how to do them in Arduino.
Thanks
Hi @gsaraullo
please, to post sketch use tags (</>).
RV mineirin
for test use this sketch:
bool once = false;
  pinMode(22, OUTPUT);
    onceloop();
void onceloop() {
//  if (Serial1.available()) {
    once = true;
  return ;
