Yes, of course! Sorry, I was at work. Now I am at home and will post the two actual codes:
Master sender:
/*Arduino 1 has the SC16IS750 connected on SDA/SCL
*TX/RX of the SC16IS750 is connected to Arduino 2
*VCC/GND
*I2C of the SC16IS750 is connected to VCC
*A0 and A1 of the SC16IS750 is connected as shown in the address table below
#include <Wire.h>
#include <SC16IS750.h>
SC16IS750 i2cuart = SC16IS750(SC16IS750_PROTOCOL_I2C,SC16IS750_ADDRESS_AA); /*Address table: A1 A0 Address
VDD VDD 0x90 => AA
VDD GND 0x92 => AB
VDD SCL 0x94 => AC
VDD SDA 0x96 => AD
GND VDD 0x98 => BA
GND GND 0x9A => BB
GND SCL 0x9C => BC
GND SDA 0x9E => BD
SCL VDD 0xA0 => CA
SCL GND 0xA2 => CB
SCL SCL 0xA4 => CC
SCL SDA 0xA6 => CD
SDA VDD 0xA8 => DA
SDA GND 0xAA => DB
SDA SCL 0xAC => DC
SDA SDA 0xAE => DD
const byte bufferSize {10};
char serialBuffer[bufferSize+1] {""};
char incomingData[bufferSize] {""};
char value[bufferSize] {""};
char variable[bufferSize] {""};
uint16_t crc = 0; //checksum crc
byte crcData[2] {""}; //create array for packet serial
byte crcDataRec[2] {""}; //create array for packet serial
int E = 0;
int F = 0;
int G = 0;
int H = 0;
int BUT = 0;
const byte DPangle = 158;
i2cuart.begin(38400);
Serial.begin(38400);
readCommand(i2cuart);
Serial.print("E = ");
Serial.println(E);
Serial.print("F = ");
Serial.println(F);
Serial.print("G = ");
Serial.println(G);
Serial.print("H = ");
Serial.println(H);
Serial.print("BUT = ");
Serial.println(BUT);
command("A01",i2cuart);
command("B57",i2cuart);
command("C"+String(DPangle),i2cuart);
command("D122",i2cuart);
command("@19",i2cuart);
void command(String value, Stream& stream) {
memset(serialBuffer, 0, sizeof serialBuffer);
sendToI2CUART(serialBuffer, value, stream);
void sendToI2CUART (char *const buffer, String command, Stream& stream)
command.toCharArray(buffer, bufferSize);
const size_t characters {strlen(buffer)};
//Serial.print("laenge: "); Serial.println(characters);
for(byte index = 0; index < characters; index++){ //create the checksum for the array data[i] with 0 <= i <= 3
crc16(buffer[index]); //call the function crc16
crc = getCRC();
byte crcIndex = characters;
byte crcIndex2 = crcIndex++;
buffer[crcIndex] = crc >> 8; //store checksum in data array
buffer[crcIndex2] = crc;
crc = 0;
for (byte i = 0; i < characters; i++){
stream.write(buffer[i]);
//Serial.print("gesendet: ");
//Serial.println(buffer[i]);
stream.write('\0');
stream.write(buffer[crcIndex]);
//Serial.print("gesendet CRC: ");
//Serial.println(buffer[crcIndex],HEX);
stream.write(buffer[crcIndex2]);
//Serial.println(buffer[crcIndex2],HEX);
stream.write('\n');
//Calculates CRC16 of nBytes of data[index] in byte array
void crc16(uint8_t data) {
int i;
crc = crc ^ ((uint16_t)data << 8);
for (i=0; i<8; i++){
if (crc & 0x8000){
crc = (crc << 1) ^ 0x1021;
else{
crc <<= 1;
uint16_t getCRC() {
return crc;
void readCommand(Stream& stream){
char var = 0;
int val = 0;
byte i = 0;
byte j = 0;
byte k = 0;
byte state = 0;
while(stream.available()) {
char m = stream.read();
if(m == '\0') {
state = 1;
i = 0;
if(m == '\n') {
state = 2;
i = 0;
switch(state){
case 0: incomingData[i++] = m;
//Serial.print("incomingData = ");
//Serial.println(incomingData[i]);
case 1: if(m != '\0'){
crcData[i++] = m;
//Serial.print("empfangen CRC: ");
//Serial.println(crcData[i]);
else {
case 2: for(byte index = 0; index < strlen(incomingData); index++){ //create the checksum for the array data[i] with 0 <= i <= 3
crc16(incomingData[index]); //call the function crc16
crc = getCRC();
crcDataRec[0] = crc >> 8; //store checksum in data array
crcDataRec[1] = crc;
crc = 0;
//Serial.print("crcData[0] = ");
//Serial.println(crcData[0],HEX);
//Serial.print("crcDataRec[0] = ");
//Serial.println(crcDataRec[0],HEX);
//Serial.print("crcData[1] = ");
//Serial.println(crcData[1],HEX);
//Serial.print("crcDataRec[1] = ");
//Serial.println(crcDataRec[1],HEX);
if(crcData[0] == crcDataRec[0] && crcData[1] == crcDataRec[1]) {
while(i <= strlen(incomingData) ) {
if(isdigit(incomingData[i]) == true) {
value[j] = incomingData[i];
j++;
i++;
else {
variable[k] = incomingData[i];
k++;
i++;
memset(incomingData, 0, sizeof incomingData);
j = 0;
k = 0;
i = 0;
val = atoi(value); //making the integer part
var = variable[0];
memset(value, 0, sizeof value);
memset(variable, 0, sizeof variable);
switch(var) {
case 'E' : E = val;
case 'F' : F = val;
case 'G' : G = val;
case 'H' : H = val;
case '#' : BUT = val;
else if(crcData[0] != crcDataRec[0] || crcData[1] != crcDataRec[1]){
state = 0;
var = 0;
val = 0;
memset(crcData, 0, sizeof crcData);
memset(crcDataRec, 0, sizeof crcDataRec);
Slave receiver:
/*Arduino 2 has the SC16IS750 connected on TX/RX
int A = 0;
int B = 0;
int C = 0;
int D = 0;
int BUT = 0;
readCommand();
Serial.print("A = ");
Serial.println(A);
Serial.print("B = ");
Serial.println(B);
Serial.print("C = ");
Serial.println(C);
Serial.print("D = ");
Serial.println(D);
command("E10");
command("F5");
command("G147");
command("H251");
command("#33");
void command(String value) {
sendToUART(serialBuffer, value);
void sendToUART (char *const buffer, String command)
crc = getCRC();
crc = 0;
Serial.write(buffer[i]);
Serial.write('\0');
Serial.write(buffer[crcIndex]);
Serial.write(buffer[crcIndex2]);
Serial.write('\n');
int i;
if (crc & 0x8000){
else{
crc <<= 1;
uint16_t getCRC() {
return crc;
void readCommand(){
char var = 0;
int val = 0;
byte i = 0;
byte j = 0;
byte k = 0;
byte state = 0;
while(Serial.available()) {
char m = Serial.read();
if(m == '\0') {
state = 1;
i = 0;
if(m == '\n') {
state = 2;
i = 0;
switch(state){
crcData[i++] = m;
else {
crc = getCRC();
crc = 0;
j++;
i++;
else {
k++;
i++;
j = 0;
k = 0;
i = 0;
var = variable[0];
switch(var) {
case 'A' : A = val;
case 'B' : B = val;
case 'C' : C = val;
case 'D' : D = val;
case '@' : BUT = val;
state = 0;
