Hi everyone!
I’m an absolute beginner in electronics, basically started with zero knowledge or experience and I’ve had an idea for a project and want to know if it is feasible before I learn more about the specific aspects of the project (it’s a long term project!).
Basically I have Hornby DC Hogwarts express train and I want to add sounds to the set. This can be done by a very expensive conversion which is unfeasible, so I’m wanting to add sound to the train on my own.
The set controlled by this analogue controller:
It uses a 19V input, and then a potentiometer(?) which is the nob control, to change the output to the track from 0-12V.
My idea is to link addition cables from the potentiometer into and Arduino Uno. The Arduino would then have an SD card (with WAV files of the train running, the whistle, wheels braking etc) and a Bluetooth transmitter capable of sending the sound files to a receiver. I would then have a Bluetooth receiver, battery and speaker which would need to be very compact that I will put in the train, probably in the tender.
Does this sound like a feasible idea? Would the Arduino be able to use the potentiometer to either speed up the train running file, or if not, vary the volume? This way the train sound will get louder and possibly faster as the train speeds. And then when the potentiometer is turned the other way, have it slow down/get quitter and also play the wheels braking sounds. Then possibly add a button to the arduino to play the whistle?
And ideas/suggestions/advice on the project would be greatly appreciated!
Thanks
MZG
Arduino project.pdf (34 KB)
