arduino sensor pir
hello I would like to add a PIR sensor to my code but I do not know ? thank you
here is my code
unsigned long time;
bool isSirenON;
int irmotionPin = 4; // Pin of IR Motion Sensor
int siren = 13; // Pin Relay
delay(30000);
isSirenON = false;
pinMode(siren, OUTPUT); // Set Pin connected to Relay as an OUTPUT
digitalWrite(siren, LOW); // Relay OFF
if (digitalRead(irmotionPin) == HIGH)
{ // If Motion detected
digitalWrite(siren, HIGH); // Turn Relay ON
isSirenON = true;
time = millis();
Serial.println("Relay is ON");
if(isSirenON)
if(millis()- time >= 10000)
digitalWrite(siren, LOW); // Turn Relay OFF
isSirenON = false;
Serial.println("Relay is OFF");
// Je peux faire autre chose en attendant.
This should work, what exactly is the problem?
Get rid of the delay() at the end of loop() , it is not doing anything useful and will just interfere
with reading the PIR.
EDIT: It's tradition here to give you a hard time for not using code tags ( </> )
See #7 How to use this forum
Good to see you carrying on the tradition! :slight_smile:
Weedpharma
Hutkikz:
I just want to change the program for 2 sensor pir ?
frankblou:
I can not change the program for 2 sensor pir
You can use this way
 if(digitalRead(irmotion1pin)==HIGH && digitalRead(irmotion2pin)==LOW) {
 //Then siren1 is on for a time
 if(digitalRead(irmotion1pin)==LOW && digitalRead(irmotion2pin)==HIGH) {
 //Then siren2 is on for a time
And use
pinMode(irmotion1pin, INPUT);
pinMode(irmotion2pin, INPUT);
digitalWrite(irmotion1pin, LOW);
digitalWrite(irmotion2pin, LOW);
in setup()
this code is for detect one motion at a time
if you want detect motion form 2 sensors
if(digitalRead(irmotion1pin)==HIGH || digitalRead(irmotion2pin)==HIGH)
for 2 sensors and just one siren it could be:
if(digitalRead(irmotion1pin) == HIGH || digitalRead(irmotion2pin) == HIGH) {
 //code to turn on siren goes here
   // this way does the same thing
if(digitalRead(irmotion1pin) || digitalRead(irmotion2pin) ) {
The bitwise || symbol means : OR
so if pir1 OR pir2 == HIGH the siren will sound.
EDIT: corrections as pointed out by ias0601 sorry I missed that bit of code in your post
I have already mentioned that
"if you want detect motion form 2 sensors
if(digitalRead(irmotion1pin)==HIGH || digitalRead(irmotion2pin)==HIGH)"
Hutkikz:
Its okay
unsigned long time;
bool isSirenON;
int irmotion1Pin = 4; // Pin of IR Motion Sensor
int irmotion2Pin = 5;// Pin of IR Motion Sensor
delay(30000);
isSirenON = false;
isSirenON = true;
time = millis();
if(isSirenON)
isSirenON = false;
I can not find my erreure ?
frankblou:
What do you mean?
I cant Understand?
change your setup() to this
 delay(30000);
 isSirenON = false;
my code not working
What is problem?
first get input from your sensor and turn a led on when input is high
then write a code to switch a relay to on with timer(Forget about pir sensor)
then write code to get input from pir sensor and relay
ok thank you
Arduino : 1.6.5 (Mac OS X), Carte : "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_dec16a.ino: In function 'void setup()':
sketch_dec16a:13: error: 'irmotion1pin' was not declared in this scope
sketch_dec16a:14: error: 'irmotion2pin' was not declared in this scope
sketch_dec16a.ino: In function 'void loop()':
sketch_dec16a:23: error: 'irmotion1pin' was not declared in this scope
sketch_dec16a:23: error: 'irmotion2pin' was not declared in this scope
Ce rapport contiendrait plus d'informations si l'option
"Montrer les informations de sortie pendant la compilation"
était activée dans Fichier > Préférences.
[/codeunsigned long time;
bool isSirenON;
int irmotion2Pin = 5; // Pin of IR Motion Sensor
 delay(30000);
 isSirenON = false;
isSirenON = true;
time = millis();
if(isSirenON)
isSirenON = false;
Case matters!
I have to do what ?
irmotion1Pin is not the same as irmotion1pin notice the capital P .
Also
Means irmotion1pin AND irmotion2pin need to be activated to sound the alarm.
if(digitalRead(irmotion1pin)==HIGH || digitalRead(irmotion2pin)==LOW)
Means irmotion1pin OR irmotion2pin need to be activated to sound the alarm.
EDIT: Oops I wrote pushed when I meant activated
