Hello.
Im have problem with code, I'm just a beginner in the Scripting Arduino cods, If someone explain or edit this prescription I'd be grateful. Thank you.
First I made my first RC car, and it went well, but I bought HC SR04, and I wish that when we robot encounters an obstacle and to stop when the robot is at 10 or 15 cm close to some barriers to stop and waiting for me to do something, thank you. I know there is somewhere on this forum, but I would not want anyone to explain to my code. Thank you
#include <NewPing.h>
const int motor1Pin1 = 5;
const int motor1Pin2 = 6;
const int motor2Pin1 = 9;
const int motor2Pin2 = 10;
byte serialA;
#define TRIGGER_PIN 7
#define ECHO_PIN 8
#define MAX_DISTANCE 200
int distance = 100;
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
pinMode(motor1Pin1, OUTPUT);
pinMode(motor1Pin2, OUTPUT);
pinMode(motor2Pin1, OUTPUT);
pinMode(motor2Pin2, OUTPUT);
delay(50);
Serial.print("Ping: ");
Serial.print(sonar.ping_cm());
Serial.println("cm");
if (Serial.available() > 0) {serialA = Serial.read();Serial.println(serialA);}
switch (serialA) {
// forward
case 'F':
digitalWrite(motor1Pin1, HIGH);
digitalWrite(motor1Pin2, LOW);
digitalWrite(motor2Pin1, LOW);
digitalWrite(motor2Pin2, HIGH);
if (distance <= 15){
digitalWrite(motor1Pin1, LOW);
digitalWrite(motor2Pin2, LOW);
// left
case 'L':
digitalWrite(motor2Pin1, HIGH);
// right
case 'R':
digitalWrite(motor1Pin2, HIGH);
// forward left
case 'G':
// forward right
case 'I':
// backward left
case 'H':
// backward right
case 'J':
// backward
case 'B':
// Stop
case 'S':
digitalWrite(motor2Pin2, LOW); }
