Arduino Serial Communication code problem
My project sends temperature sensor data to a phone using GSM module 900. But also on receiving some specific command from a number it switches ON or OFF some pins(see the 'fan()' function). The problem is that when I don't connect my GSM Module to Arduino, it works perfectly fine. but when I connect it to the module, it doesnt work properly. I guess its due to data coming from Module other than the command I sent is causing trouble. Please tell me how to filter out the data. Here is the code :
double tempD,tempA;
char inchar;
long prevtime=0;
  pinMode(12, OUTPUT);
  pinMode(11, OUTPUT);
  Serial.println("AT+CSMS=1\r");
 delay(200);
  Serial.print("AT+CNMI=2,2,0,0,0");
  delay(300);
  Serial.print('\n');
{ unsigned long time = millis();
 if(time-prevtime>100000)
 { prevtime=time;
   message();
fan();
  void message()
{ temperature();
  Serial.print("\r");
  Serial.print("AT+CMGF=1\r");
  Serial.print("AT+CMGS=\"+917709777239\"\r");
  Serial.println('\r');
  Serial.print("\n");
  Serial.print("Temperature=");
  Serial.println(tempD);
  Serial.print('\r');
  Serial.print("---REPLY---");
  Serial.print('\n');
  Serial.print("'1' for FAN ON, Motor ON");
     Serial.print('\n');
     Serial.print("'2' for FAN ON, Motor OFF");
     Serial.print('\n');
     Serial.print("'3' for FAN OFF, Motor ON");
     Serial.print('\n');
     Serial.print("'0' for FAN OFF, Motor OFF");
     Serial.print('\n');
  delay(800);
  Serial.write(0x1A);
void fan()
   if(Serial.available()>0)
  {  inchar=Serial.read();
    if (inchar=='1')
      digitalWrite(12, HIGH);
      digitalWrite(13,HIGH);
    else if (inchar=='2')
     digitalWrite(13, LOW);
     else if (inchar=='3')
      digitalWrite(12, LOW);
     digitalWrite(13, HIGH);
     else if (inchar=='0')
     { digitalWrite(12, LOW);
    else if (inchar=='M' || inchar=='m')
      message();
   Serial.println("AT+CMGR=1\r");
  delay(2000);
double temperature()
  tempA=analogRead(A0);
  tempD = (5.0 *tempA * 100.0) / 1023;
  return tempD;
Every AT command generates a response. Ignoring the response makes debugging a guessing game.
Get the GSM off the Serial port. Use that for debugging. Use SoftwareSerial to talk the GSM module, and quit guessing.
