Arduino serial communication
Ok... So here is my problem: I want to make a temperature monitoring application. Now, I am using an LM35DZ which is directly calibrated in deg. Celsius (10mV/C). What I want to do is send from my PC, via serial comm, a command to arduino that will make the conversion from C to F or K. This is the code that I got so far.
int inPIN = 0;
float v = 0;
unsigned long time = 0;
float t=0;
  pinMode(LEDPIN, OUTPUT);
  // send data only when you receive data:
        inPIN = analogRead(A0);
          time=millis();
          v = (float)inPIN/204.6;
 // if (Serial.available() > 0)
    int incomingState = Serial.read();
    if(incomingState == '1')
        t=(100*v)*9/5+32;
     if(incomingState == '2')
       t=(100*v)+273.15;
    if(incomingState == '3')
       t=v*100;
  Serial.println(t, DEC);
  Serial.println(time, DEC);
Ok. So, this is the code. The code actually works but if I press 1 for example to convert to F, it just repeats the value it converted at the moment the command was processed. Here is what I get:
39756
25.4154434204
39779
25.4154434204
39801
25.4154434204
39825
25.4154434204
39847
25.4154434204
39870
25.4154434204
39894
25.4154434204
39916
25.4154434204
39939
25.4154434204
39962
25.4154434204
My question is: how do I do this conversion and output the correct values? I hope I was clear...
If there is no data in the serial buffer Serial.read() returns -1. Therefore, except when you actually press the key, incomingState is being set to -1, and t is never re-computed.
Perhaps you just want
if (Serial.available() > 0) incomingState = Serial.read();
Though you probably want some checking to preserve incomingState if the user presses something other than 1, 2, or 3; otherwise you have the same problem.
Actually, you pretty much have it - just uncomment a few lines and move the print functions inside the loop:
int inPIN = 0;
float v = 0;
float t=0;
          time=millis();
        t=(100*v)*9/5+32;
       t=(100*v)+273.15;
       t=v*100;
Oh my god... it was so simple :D Thank you Professor Chaos. Your reply made me think and look again at the code from a different point of view. :D
And wildbill was right, the code was there already. I just had to look again. Thanks for the replies :).
The actual code that works... missed a variable declaration at the beginning and ... a } in another place. I marked the changes in the code. I will post the code, who knows, maybe someone will need the info.
int inPIN = 0;
float v = 0;
float t=0;
int in=0; //this is one line I had to add...
          time=millis();
          t=v*100; //added this line so it is on Celsius by default
 {in = Serial.read();} //here is another modification
    if(in == '1')
        t=(100*v)*9/5+32;
     if(in == '2')
       t=(100*v)+273.15;
    if(in == '3')
       t=v*100;
