Arduino Serial Monitor switching between data
Hi i have 2 sets of weighing scales and i can run the code so that it will tell me the weight of the 1st scale for 10 seconds and then it tells me the weight of the second weighing scale for 10 seconds.
is there a way i can use a function on the serial monitor that i can press either 1 or 2 to switch between which weighing scale i want to look at?
Yes.
Mark
is it ok if you could show me an example of code where this can be done? :slight_smile:
Your program will have to read a character from Serial, if one is available and then compare it. If it is a '1' then show scale 1. If it is a '2' then show scale 2. If it is something else (like a carriage return, newline,...) then just ignore it.
Look at the examples in the IDE. File->Examples->Communication->ReadASCIIString
#include "HX711.h"
#define calibration_factor1 20500
#define calibration_factor2 20800
#define DOUT1 3
#define CLK1 2
#define DOUT2 5
#define CLK2 4
HX711 scale1;
HX711 scale2;
unsigned long time_since_last_reset = 0;
int interval_one = 500;
int interval_two = 500;
Serial.println("HX711 scale demo");
scale1.begin(DOUT1, CLK1);
scale1.set_scale(calibration_factor2); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale1.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings1:");
scale2.begin(DOUT2, CLK2);
scale2.set_scale(calibration_factor1); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale2.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings2:");
time_since_last_reset = millis();
while((millis() - time_since_last_reset) < interval_one){
Serial.print("Warehouse Reading:");
Serial.print(scale1.get_units(), 4); //scale.get_units() returns a float
Serial.print(" kg"); //You can change this to kg but you'll need to refactor the calibration_factor
while((millis() - time_since_last_reset) < interval_two){
Serial.print("Shop floor Reading:");
Serial.print(scale2.get_units(), 4); //scale.get_units() returns a float
Serial.println();}
sorry still dont understand after looking at the example.
Yes i want to be able to press 1 in the serial monitor to view scale 1 or
i want to be able to press 2 in serial monitor to view 2. but what function would i use to make it do that?
