Arduino serial output to CSV file.
Hello folks, I'm looking for a way to get an arduino serial outputs in CSV file?
Copy and paste from the Serial Monitor window?
Write a program in Processing, Java, Basic, VisualC?
Use a terminal emulator that can log input to a file ?
UKHeliBob: Use a terminal emulator that can log input to a file ?
PuTTY can do this.
Realterm is another application that can do it.
Or you could use Gobetwino, if you're running on Windows.
There's also a plug-in for Excel that can capture input from a serial port and append to an open spreadsheet, which might or might not be useful, depending what you're trying to do.
