I have commented out a lot of the code trying to isolate what's going on. The serial.print works until I add in the while loops in setup to home my stepper motors.
I just want to see the voltage at pin A4 Why would this be and how can I fix it? Thanks!
//CONSTANTS THAT DONT CHANGE. ASSIGNING PIN NUMBERS
const int STEPPER01_DIR = A2;
const int STEPPER01_STEP = A3;
const int LANE1LED = A4;
const int LANE2LED = A5 ;
const int STEPPER02_DIR = 3;
const int STEPPER02_STEP = 4;
const int LIMITSWITCH1 = 5;
const int LIMITSWITCH2 = 6;
const int RELAY_RED = 7;
const int RELAY_GREEN = 8;
const int RELAY_SHREDDER = 9;
const int BUTTON_SHRED = 10;
const int BUTTON_RESET = 11;
//VARIABLES THAT WILL CHANGE. SET UP DIGITAL INPUTS
int buttonstate_shred = 0;
int buttonstate_reset = 0;
int buttonstate_limit1 = 0;
int buttonstate_limit2 = 0;
int steps1;
int steps2;
//starting accelstepper
#include <AccelStepper.h>;
AccelStepper stepper1(1,STEPPER01_STEP,STEPPER01_DIR);
AccelStepper stepper2(1,STEPPER02_STEP,STEPPER02_DIR);
//STATING WHAT EACH PIN DOES (INPUT OR OUTPUT)
pinMode(STEPPER01_DIR,OUTPUT);
pinMode(STEPPER01_STEP,OUTPUT);
pinMode(STEPPER02_DIR,OUTPUT);
pinMode(STEPPER02_STEP,OUTPUT);
pinMode(LIMITSWITCH1,INPUT_PULLUP);
pinMode(LIMITSWITCH2,INPUT_PULLUP);
pinMode(RELAY_RED,OUTPUT);
pinMode(RELAY_GREEN,OUTPUT);
pinMode(RELAY_SHREDDER,OUTPUT);
pinMode(BUTTON_SHRED,INPUT_PULLUP);
pinMode(BUTTON_RESET,INPUT_PULLUP);
//pinMode(LANE1LED,INPUT);
//pinMode(LANE2LED,INPUT);
stepper1.setMaxSpeed(750);
stepper2.setMaxSpeed(750);
stepper1.setAcceleration(1000);
stepper2.setAcceleration(1000);
stepper1.setCurrentPosition(0);
stepper2.setCurrentPosition(0);
//STEPPER HOMING
//stepper 1
while (digitalRead(LIMITSWITCH1))
{digitalWrite(STEPPER01_DIR, HIGH);
digitalWrite(STEPPER01_STEP, HIGH);
delay(5);
digitalWrite(STEPPER01_STEP, LOW);
delay(5);}
while (!digitalRead(LIMITSWITCH1))
{digitalWrite(STEPPER01_DIR, LOW);
delay(10);
delay(10); }
steps1=0;
//stepper 2
while (digitalRead(LIMITSWITCH2))
{digitalWrite(STEPPER02_DIR, HIGH);
digitalWrite(STEPPER02_STEP, HIGH);
delay(5);
digitalWrite(STEPPER02_STEP, LOW);
delay(5);}
while (!digitalRead(LIMITSWITCH2))
{digitalWrite(STEPPER02_DIR, LOW);
delay(10);
delay(10); }
steps2=0;
//digitalWrite(RELAY_GREEN, HIGH);
//stepper tester
//stepper1.moveTo(400);
//stepper1.run();
//stepper2.moveTo(400);
//stepper2.run();
//INSERT CODE THAT DECIDES WHO WON HERE
int sensorValue = analogRead(LANE1LED);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
//int LANE1 = analogRead (LANE1LED);
//Serial.println(LANE1);
//int LANE2 = analogRead (LANE2LED);
//Serial.println(LANE2);
//if lane one wins
//delay(1000);
//digitalWrite(RELAY_GREEN, LOW);
//digitalWrite(RELAY_RED, HIGH);
//stepper1.moveTo(4000);
//stepper1.run();
////digitalWrite(RELAY_SHREDDER, HIGH);
//stepper1.moveTo(50);
//stepper1.run();
//turns on the shredder when you press the shredder button
//buttonstate_shred=digitalRead(BUTTON_SHRED);
//if (buttonstate_shred == LOW){
//digitalWrite(RELAY_SHREDDER, HIGH);}
//else{
//digitalWrite(RELAY_SHREDDER, LOW);}
