Arduino Serial Problems
Hi all,
I’ve got some code (there’s a lot of it, hence why I’m not posting straight away) that polls two analog inputs, stores the values temporarily in RAM, then serves up a serial string consisting of a S/N and the two archived values.
Now, the code works, for a few minutes, then just seems to flake out, mid-string.
I’m using the default serial rate of 9600 bps, with a FT-232 Adapter board.
I’ve tried the code on a variety of boards (MEGA 1280, Mini Pro 328, Demilunovae and a selection of hand-built boards), to no avail…
Changing the program cycle frequency seems to have no effect, with the code eventually halting abruptly mid-string, every time(!).
Here’s the function for sending the data string…
void transmit_packet(int RH,int temp)
xb_awake();
xb_init();
// Serial.print("&");
for (int i = 0; i<6;){
Serial.print(serial*);*
  • i++;}*
_ Serial.print(",");_
  • // Serial.print(“T=”);*
    _ Serial.print(temp);_
    _ Serial.print(RH);_
    _ Serial.println("");_
  • xb_sleep();*
    [/quote]
    And the main program flow…
    > void loop() //MAIN PROGRAM
    > get_data(); // Poll Analog Inputs
    > transmit_packet(RH, temp); // Pass data to xBee for transmission
    > delay(transmission_delay);
    > check_serial_num();
    > loop(); // Loop Around
    I haven’t included the get_data function, as I don’t think it’s causing any problems, but its pretty simple, read A0 and A1, store to variables RH and temp.
    The code seems to be breaking mid-flow of transmit_packet, and it’s left me at a loss… :-/
    Has anyone experienced anything similar when going heavy on the Serial.print function?
    Thanks all,
    Tom
Here’s your problem:
  check_serial_num();
  loop();                          // Loop Around [glow]<---- NOOOOO!!!!!!![/glow]
You should not have loop() calling itself as you will eventually smash the available stack space on the processor. loop() is called in a loop anyways…there is no need for you to keep calling it.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Hi there.
I have a similar problem ith a NANO-board. That is that when I run a program that sends out strings (regular intervals ~ 1sec) the program seems to halt after a while when I don’t read the data.
The program flow is monitored by an activity-led (13) when the data is sent. When I plug the USB back in or read data the program resets (values are re-initialized!)
The problem is that the board is intended for stand-alone use and sometimes can be monitored for correct functioning.
Anyone an idea?
Anyone an idea?
Create a new topic in the Software section where your problem can be discussed.
Post your entire Sketch using code tags.
Include a detailed description of what is happening and what you expect to happen.
