Arduino Serial.read help
So I am brand new to Arduino, and a complete novice, so please excuse me if this is a really dumb question
I wrote this code:
int incomingByte = 0;
if (Serial.available() > 0) {
incomingByte = Serial.read();
if( incomingByte == 'h'){
Serial.println("test line");
and what I am wondering is this, can I make the incomingByte equal to a full word? I tried 'test' which yielded no results. Do i need to play around with the DEC for each letter? I would much appreciate any help of the matter from you learned arduino folk
Not unless the word is "a" or "I", no.
Have you looked at the examples in the IDE?
thanks for the quick reply,
is there any other way to go about this that would allow you to enter in more than one digit inputs?
I have skimmed through some of the IDE examples
As a starting point, try:
char buff[21];
int charsRead;
    charsRead = Serial.readBytesUntil('\n', buff, 20);
    buff[charsRead] = '\0';
    Serial.println(buff);
and figure out what each section of code does. You should be able to modify it to suit your needs.
thanks I will give it a try
You may find some useful stuff in the demos here and here
The Arduino code in the second demo will also work with the Serial Monitor.
...R
If your "word" is a multi character string, then you can capture the character string sent into a String, then evaluate the captured String for what it contains. Very simple example below.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
    if (readString == "off")
      digitalWrite(ledPin, LOW);
    readString="";
