Readings are fine and works well. I need to receive them in integers. my purpose is to on/off a relay according to scale data. Please help me out. thanks
Type here as a post what you are seeing on the Serial Monitor.
Note that the Software Serial Port works well at Bd = 9600. In that case, if you are using UNO, then you might need to connect your scale with Hardware UART Port. If you are using MEGA, then connect your scale with Serial1/UART1.
And still, there is a way to operate the scale using Hardware UART Port of UNO at Bd = 19200 and viewing the incoming signal on Serial Monitor using Software Serial Port for which you need another TTL <---->RS232 converter.
where msb is the most significance bit and lsb is the least significant bit, with intValue is the integer value you want.
Do you know what order the values are sent?
Assuming you get the msb first then try a function:-
int ReadInt(){
while (Serial.available() >0) ; // hold until you have a byte to read
msb = Serial.Read():
lsb = Serial.Read():
intValue = (msb << 8) | lsb);
return(intValue);
Variables would be globals.
This would use the normal serial, port which uses pins 0&1 and you would use a double pole switch to isolate these pins when programming them.
However, you need to tell us more about your application.
Are you tapping into an ongoing stream, or can you start the program first and then start the stream?
If it is an ongoing stream then you need to sort out the order in some other way maybe from some property between msb and lsb.
You're going to want to read the scale data into a "string". It can be converted into an integer but if all you want is the weight on the scale to act as the switch simply set a threshold. Basically a software limit switch. Lots of ways to code that if, while, for statements/loops. You can have two serial variables one for the monitor and one for the scale readings.
This code might work for you.
const int relayPin = 8; // Pin connected to the relay
const int weightThreshold = 500; // Example threshold value in grams (adjust as needed)
// Initialize serial communication with the computer
// Initialize serial communication with the digital scale at 19200 baud rate
Serial1.begin(19200); // Serial1 is used for pin 0 (RX) and pin 1 (TX)
// Set the relay pin as output
pinMode(relayPin, OUTPUT);
// Ensure the relay is off at the start
digitalWrite(relayPin, LOW);
// Check if data is available from the digital scale
if (Serial1.available()) {
String weightData = ""; // Initialize a string to hold the incoming data
// Read the incoming data from the scale
while (Serial1.available()) {
char incomingByte = Serial1.read();
weightData += incomingByte;
// Convert the weight data to an integer
int weight = weightData.toInt();
// Print the received data to the Serial Monitor
Serial.print("Weight: ");
Serial.println(weight);
// Check if the weight exceeds the threshold
if (weight > weightThreshold) {
// Turn the relay on
digitalWrite(relayPin, HIGH);
Serial.println("Relay ON");
// Turn the relay off
Serial.println("Relay OFF");
delay(500); // Add a small delay to prevent flooding the serial monitor
The @yeshantcc has not told us about the scale and whether it is sending the weight data as a character string or or as the bytes of either integer or float data.
The attached images in the first posting would indicate the character string is being sent, and in that case atoi would be appropriate.
Thanks for this code, But it did not work. My scale is ADAM GBK 32. And I have manager to lower its bit rate to 600. Can you please edit on my code. I am capable of writing the relay code. I need more than one relay to work on. I need you help on reading the code as a number. RX TX as 8 and 8 can you help editing this code. much apricated`
I am receiving weight values but cannot control the relay due to unwanted characters
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 9);
const byte numChars = 25;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
float number = 0;
float YR =0;
Serial.begin(600);
//Serial.println("<Arduino is ready>");
mySerial.begin(600);
recvWithEndMarker();
if (newData)
showNewData();
number = atof(receivedChars);
newData = false;
void recvWithEndMarker()
static byte ndx = 0;
char endMarker = '\r'; // 0x0d carriage return
char rc;
while (mySerial.available() > 0 && newData == false)
rc = mySerial.read();
if (rc != endMarker)
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars)
ndx = numChars - 1;
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewData()
//Serial.print("This just in ... ");
Serial.println(receivedChars);
Serial.println(number);
delay(500) ;
