Arduino & Serial
Hello!
I am using an arduino Duemilanove with 16x2 lcd to get info from LCDSmartie,
My Code:
//LCD
#include <avr/interrupt.h>
#include <avr/io.h>
#include "LCD4Bit_mod.h"
LCD4Bit_mod lcd = LCD4Bit_mod(2);
byte rxbyte;
byte temp;
pinMode(latchPin, OUTPUT);
Serial.begin(19200);
  lcd.init();
  lcd.clear();
  lcd.printIn("LCD TEST");
  lcd.cursorTo(2,2);
  lcd.printIn(" LINE 2");
 //LCD
 byte serial_getch(){
  int incoming;
  while (Serial.available() == 0){}
      // read the incoming byte:
  incoming = Serial.read();
  return (byte) (incoming &0xff);
if(Serial.available() > 0) {
rxbyte = serial_getch();
  if (rxbyte == 254) //Matrix Orbital uses 254 prefix for commands
            switch (serial_getch())
                  case 66: //backlight on (at previously set brightness)
                                // not implemented
                  case 70: //backlight off
                        // not implemented
                  case 71:  //set cursor position
                        temp = (serial_getch() - 1);  //get column byte
                        switch (serial_getch())  //get row byte
                              //line 1 is already set up
                              case 2:
                                    temp += 0x40;
                              case 3:
                                    temp += 0x14;
                              case 4:
                                    temp += 0x54;
                              default:
                        lcd.commandWrite(0b10000000 + temp);
                  case 72:  //cursor home (reset display position)
                        lcd.commandWrite(2);
                  case 74:  //show underline cursor
                        lcd.commandWrite(0b00001110);
                  case 75:  //underline cursor off
                  case 84:  //block cursor off
                        lcd.commandWrite(0b00001100);
                  case 76:  //move cursor left
                        lcd.commandWrite(16);
                  case 77:  //move cursor right
                        lcd.commandWrite(20);
                  case 78:  //define custom char
                        lcd.commandWrite(64 + (serial_getch() * 8));  //get+set char address
                        for (temp = 7; temp != 0; temp--)
                              lcd.print(serial_getch()); //get each pattern byte
                  case 83:  //show blinking block cursor
                        lcd.commandWrite(0b00001111);
                  case 86:  //GPO OFF
                        //implement later
                  case 87:  //GPO ON
                        /*temp = serial_getch();
                        if (temp == 1)
                              GPO1 = GPO_ON;
                  case 88:  //clear display, cursor home
                        lcd.commandWrite(1);
                  case 152: //set and remember (doesn't save value, though)
                  case 153: //set backlight brightness
                        //not implemented
                  //these commands ignored (no parameters)
                  case 35: //read serial number
                  case 36: //read version number
                  case 55: //read module type
                  case 59: //exit flow-control mode
                  case 65: //auto transmit keypresses
                  case 96: //auto-repeat mode off (keypad)
                  case 67: //auto line-wrap on
                  case 68: //auto line-wrap off
                  case 81: //auto scroll on
                  case 82: //auto scroll off
                  case 104: //init horiz bar graph
                  case 109: //init med size digits
                  case 115: //init narrow vert bar graph
                  case 118: //init wide vert bar graph
                  default:
                        //all other commands ignored and parameter byte discarded
                        temp = serial_getch();  //dump the command code
            return;
      } //END OF COMMAND HANDLER
      //change accented char to plain, detect and change descenders
      //NB descenders only work on 5x10 displays. This lookup table works
      //  with my DEM-20845 (Display Elektronik GmbH) LCD using KS0066 chip.
switch (rxbyte)
            //chars that have direct equivalent in LCD charmap
/*            case 0x67: //g
                  rxbyte = 0xE7;
            case 0x6A: //j
                  rxbyte = 0xEA;
            case 0x70: //p
                  rxbyte = 0xF0;
            case 0x71: //q
                  rxbyte = 0xF1;
            case 0x79: //y
                  rxbyte = 0xF9;
*/            case 0xE4: //ASCII "a" umlaut
                  rxbyte = 0xE1;
            case 0xF1: //ASCII "n" tilde
                  rxbyte = 0xEE;
            case 0xF6: //ASCII "o" umlaut
                  rxbyte = 0xEF; //was wrong in v0.86
            case 0xFC: //ASCII "u" umlaut
                  rxbyte = 0xF5;
            //accented -> plain equivalent
            //and misc symbol translation
            case 0xA3: //sterling (pounds)
                  rxbyte = 0xED;
/*            case 0xB0: //degrees symbol
                  rxbyte = 0xDF;
*/            case 0xB5: //mu
                  rxbyte = 0xE4;
            case 0xC0: //"A" variants
            case 0xC1:
            case 0xC2:
            case 0xC3:
            case 0xC4:
            case 0xC5:
                  rxbyte = 0x41;
            case 0xC8: //"E" variants
            case 0xC9:
            case 0xCA:
            case 0xCB:
                  rxbyte = 0x45;
            case 0xCC: //"I" variants
            case 0xCD:
            case 0xCE:
            case 0xCF:
                  rxbyte = 0x49;
            case 0xD1: //"N" tilde -> plain "N"
                  rxbyte = 0x43;
            case 0xD2: //"O" variants
            case 0xD3:
            case 0xD4:
            case 0xD5:
            case 0xD6:
            case 0xD8:
                  rxbyte = 0x4F;
            case 0xD9: //"U" variants
            case 0xDA:
            case 0xDB:
            case 0xDC:
                  rxbyte = 0x55;
            case 0xDD: //"Y" acute -> "Y"
                  rxbyte = 0x59;
/*            case 0xDF: //beta  //mucks up LCDSmartie's degree symbol??
                  rxbyte = 0xE2;
*/            case 0xE0: //"a" variants except umlaut
            case 0xE1:
            case 0xE2:
            case 0xE3:
            case 0xE5:
                  rxbyte = 0x61;
            case 0xE7: //"c" cedilla -> "c"
                  rxbyte = 0x63;
            case 0xE8: //"e" variants
            case 0xE9:
            case 0xEA:
            case 0xEB:
                  rxbyte = 0x65;
            case 0xEC: //"i" variants
            case 0xED:
            case 0xEE:
            case 0xEF:
                  rxbyte = 0x69;
            case 0xF2: //"o" variants except umlaut
            case 0xF3:
            case 0xF4:
            case 0xF5:
            case 0xF8:
                  rxbyte = 0x6F;
            case 0xF7: //division symbol
                  rxbyte = 0xFD;
            case 0xF9: //"u" variants except umlaut
            case 0xFA:
            case 0xFB:
                  rxbyte = 0x75;
            default:
      lcd.print(rxbyte);  //otherwise a plain char so we print it to lcd
I am using the code available on the website http://www.nuelectronics.com/estore/index.php?main_page=project_lcdsmartie
My Problem: When only have the usb cable connected, and the LCDSmartie off, it sends to the LCD the character "6", can I stop this?
Vídeo: Erro1 - YouTube
how can I quit lcdsmartie and leave only the msg that on the lcd without arduino write me constantly the character '6 '..?
I do not know if I explained well...
