I would like to ask if there is a reason why by using Servo.h the analogWrite command for the motor PWM control is not working. To be more specific i need to control a servo position and a DC motor’s speed and direction. This program will be applied to a boat. The program is receiving values from the serial port and then translating them to integer values. For servo 0-180 and motor from 100-255 (it requires a lot of A). Now for some reason the program when receives command for the motor at first it starts ok. But after servo is initialized the motor stops working. The pins that are used are servo pin 3, motor direction1 pin 11, motor direction2 pin 8, motor speed pin 9. Arduino 0017 is used. Does anyone knows why this happens?
I don't think anyone could have a clue unless you first post your code. Use the # button to embed your program and see if anyone here can help you.
Lefty
Thanks for the answer. Here is the code. Still needs some cleanup and commenting.
#include <Servo.h>
int speedPinA= 9 ;
int dir1PinA = 11;
int dir2PinA = 8;
Servo rudder;
int speed=255;
char sp;//This is the speed variable for the motors
char selection; //This is the received command
unsigned int dir=0;
unsigned int angle=0;
char pos[3]={NULL};
Serial.begin(9600); //setup the serial port to 9600bps
//seting the pins options
pinMode(dir1PinA, OUTPUT);
pinMode(dir2PinA, OUTPUT);
pinMode(speedPinA,OUTPUT);
rudder.attach(3);
for (int i=0;i<3;i++){
pos[i]=NULL;
if (Serial.available()>0){ //check if something was received
selection=Serial.read(); //store it to inbyte
switch (selection){
case 's':{
if (Serial.available()>0) {
pos[0]=Serial.read();}
Serial.write("first");
pos[1]=Serial.read();}
Serial.write("second");
pos[2]=Serial.read();
Serial.write("third");}
Serial.write("Servo");
if (pos[1]==NULL && pos[2]==NULL){
Serial.write("-1 digit:");
angle=atoi(&pos[0]);}
else if (pos[2]==NULL){
Serial.write("-2 digits:");
angle=atoi(&pos[0])*10+atoi(&pos[1]);}
else if (pos[0]!=NULL && pos[1]!=NULL && pos[2]!=NULL) {
angle=atoi(&pos[0])*100+ atoi(&pos[1])*10 +atoi(&pos[2]);
Serial.write("-3 digits:");}
Serial.print(angle,DEC);
ruddermove(angle);
case 'm':{
Serial.write("Motor");
dir=Serial.read();
Serial.write(dir);
speed=Serial.read();
Serial.write(speed);
analogWrite(speedPinA,speed);
motor(dir);
Serial.flush();
void motor(int dir){
switch (dir){
case 49:{
digitalWrite(dir1PinA, LOW);
digitalWrite(dir2PinA, HIGH);
Serial.write("right");
break;}
case 50:{//if the received command is 2 in ASCII code start spinning
digitalWrite(dir1PinA, HIGH);
digitalWrite(dir2PinA, LOW);
Serial.write("left");
break;}
case 48:{//if the received command is 0 in ASCII code stop
digitalWrite(dir1PinA,LOW);
Serial.write("stop");
void ruddermove(unsigned int angle){
rudder.write(angle);
Which version of the IDE are you using? There have been some changes to the servo library for various versions of the IDE.
Why are you flushing the serial buffer?
In the motor function, there are cases for 48, 49, 50. Strange numbers for the cases. What do they mean? ‘0’, ‘1’, and ‘2’ would make a lot more sense. Even better, though, would have been to subtract ‘0’ from all the values before calling the motor function, passing it 0, 1, or 2.
Better than that, though, would be to add these to the top of the code
#define STOP 0
#define RIGHT 1
#define LEFT 2
and use these in the case statements.
Whatever you do, make the comments match the code. Much easier to debug when the code matches the comments.
In loop, you check that there is serial data available each time before read. That’s good. But, suppose there is a slowdown in serial communication. You check that there is a byte for selection. There is, so you read it. Then, you check for a byte for pos[0]. There is, so you read it. Then, you check for a byte for pos[1]. Suppose there isn’t. You skip reading a value for pos[1], which stays NULL. The byte has arrived by now, so you read it into pos[2].
What was supposed to be something like s72 has become ‘s’, ‘7’, NULL, ‘2’.
You then take action based in ‘s’, ‘7’.
Whatever is sending data should send something like ‘<’, ‘s’, ‘7’, ‘2’, ‘>’. Now the string has a defined start and stop value, and you can read the data in a (much shorter) while loop, storing the characters between the ‘<’ and the ‘>’ in adjacent positions in an array. Knowing that the first character is a character, and that subsequent characters are digits also allows you to ignore invalid data.
Garbled transmissions, like ‘<’, ‘s’, ‘7’, ‘&’, ‘<’, ‘s’, ‘8’, ‘4’, ‘>’ can be handled correctly.
Thanks for your answers. You have pointed to me some stuff that it would take me hours to solve. I have now finally solved the problem with the servo angle of movement. Now as for the problem with the motor i don’t know what should i do, since i am using a motor controller shield not configurable about the speed pins. The are pre-configured to 9 and 10 from the factory. This is my code commented and clean.
#include <Servo.h>
#define Forward 50
#define Reverse 49
#define mstop 48
int speedPinA= 9 ;
int dir1PinA = 11;
int dir2PinA = 8;
unsigned int dir=0;
Servo rudder;
char pos[3]={NULL}; //This is the received angle string
rudder.attach(3);
pos[i]=NULL; //Initialize values to 0
if (Serial.available()>=0){
switch (selection){
case 's':{ //servo is selected
waitmsg(); //wait for value
pos[0]=Serial.read(); //store the first digit to the 1st char of the string
waitmsg();//wait for value
pos[1]=Serial.read();//store the first digit to the 2nd char of the string
pos[2]=Serial.read(); //store the first digit to the 3rd char of the string
angle=conv(pos[0])*100+ conv(pos[1])*10 +conv(pos[2]); //convert the number to integer decimal. each digit represents the hundrends, tenths and units respectively
rudder.write(angle); //move the rudder
break; //exit the switch statement
case 'm':{
dir=Serial.read();//read the direction
digitalWrite(speedPinA,HIGH); //set the motor pin to high
motor(dir); //write the direction of the motor
//-------------------------------FUNCTION DECLARATION POINT-------------------------------------------------------------
/*this procedure reads the direction of the motor and according to the received value
(0=Stop, 1=Reverse,2=Forward) the motor moves*/
switch (dir){
case Reverse:{//Start motor spinning
break;}
case Forward:{//Start motor spinning
break;}
case mstop:{//Stop motor spinning
//this function converts ascii characters to integer values
int conv(char num){
if (num>=48 && num<=57){ //check if the char is in the corresponding values between 48 and 57 (0-9)
return ( num-'0'); //return the integer value from char-48
else{ //this is not a valid char number
return 0;
//this is a loop in order to wait from the serial port a value to be read. If the value is received the it exits the loop
void waitmsg(){
while(Serial.available()<=0){}
Everything is working fine but the speed controlling of the motor is missing. The motor is just start spinning at maximum speed. In order to add motor speed control functionality i just need to read the speed variable from the serial and to analogwrite the motor speed pin. I just dont know yet how to enable those pins… Does anyone have any idea?
What motor controller shield are you using?
i am using this: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160374483318&ssPageName=ADME:X:AAQ:US:1123 ( not trying to sell anything. i just need help)
That sets the speed. HIGH jams the throttle to the floor.
digitalWrite(speedPinA, 75); //set the motor speed to 75/255 of full throttle
Easy on the throttle...
Write whatever value you like, from 0 to 255. There are practical limits to the speed control. You may not get any motion until you get above some value, and you are unlikely to detect a difference between say 189 and 190.
PaulS by Digitalwrite the output can be either HIGH or LOW not some value from 0-255. Values are only used in analogwrite (for PWM) which right now is disabled by the Servo.h library. My question is there a way to remove the pin 9-10 disabling from the library, or even other similar library that doesn't have this cons?
analogWrite is implemented in Arduino using Timers to generate the PWM signal. The pins associated with a timer is fixed into the design of the Arduino chip and can't be changed. The Arduino Servo library uses the 16 bit timer which is fixed to pins 9 and 10, so using the Servo code prevents these pins from being available to analog write.
There are a couple of workarounds.
You can use a software servo library that does not use a timer but does require that your sketch call a refresh function at least once every 50ms (ideally 20ms) See: http://www.arduino.cc/playground/ComponentLib/Servo
If calling the explicit refresh is inconvenient, I posted a library here that uses timer2 (pins 3 and 11 are disabled). This Servo library distributed with Arduino is more capable and efficient than ServoTimer2 but this library will free up pins 9 and 10.
The thread is here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230479947 You can download the library from here: http://www.arduino.cc/playground/uploads/Main/ServoTimer2.zip.
