does anybody know, how many microsecond correlate with one degree?
I just know, that 90 degree correlate with 1500 ms. But what correlate with 180 or 0 degree?
I am interested in the data of the servo libary, not in the data of any servo.
Thanks you, that means, if I am working with a servo, where 0 degree are equal 600us and 180 degrees are equal 2400us I should work with us and not with degrees?
Inside the directory you will generally find a .h file and a .cpp file, these are the source code files used to build the library.
Inside servo.h you will find the following limits have been set -
define MIN_PULSE_WIDTH 544 // the shortest pulse sent to a servo
define MAX_PULSE_WIDTH 2400 // the longest pulse sent to a servo
You could adjust these to give a wider range, but I would assume these are provided by the library creators to prevent damage to the vast majority of servos.
Inside the write function in servo.cpp you will find
value = map(value, 0, 180, SERVO_MIN(), SERVO_MAX());
So the range 0,180 is mapped to 544 to 2400 microseconds (unless you specifically set some other limits) which gives 10.31 uS per degree. I may have missed something so feel free to check and correct.
Using a bamboo skewer like below as a pointer to detect small movements, I've found that a standard servo has a ~5us dead band between discrete movements. That equates to only ~425 discrete positions in ~190 deg rotation.
In my observation, the input signal varies by 40us for a constant input signal, the variation increases with distance and the nature of the built up environment around the transmitter receiver.
