Arduino + servos multiples
I have an arduino uno and three servosMotores, but I can not move them, my arduino flashes the LED, but nothing happens when I turn the three engines together. Does anyone know why this happens and how can I solve this. My code in IDE is below:
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
  myservo1.attach(9);
  myservo2.attach(10);
  myservo3.attach(11);
     myservo1.write(35);
     myservo2.write(35);
     myservo3.write(35);
    delay(15);
     myservo1.write(45);
     myservo2.write(45);
     myservo3.write(45);
    delay(15);
     myservo1.write(90);
     myservo2.write(90);
     myservo3.write(90);
    delay(15);
Help me, please!
Servos require more current pins output 40ma Max.
steinie44:
A little error here, I think.
It is true that the absolute max current for an I/O pin is 40mA. That is quite adequate for the signal for a servo
However I doubt if the OP is trying to power the servos from the I/O pins but it is quite likely he is trying to power them from the Arduino 5v pin. Servos should have their own power supply with a common ground connection to the Arduino.
The Arduino 5v pin can supply a lot more than 40mA but not enough for servos. When the servos try to move they will cause the voltage to fall and then the Arduino will reset - and the Arduino voltage regulator might be damaged.
...R
And here's a pic of what Robin's saying.
Conventional forum wisdom is to allow 1A per servo.....
