Arduino Servo's with button switch
Hello,
I'm new with Arduino.
i have this code and if i run i, it counts automatically....
Does anyone know how to fix it, I have tried everything but nothing helps:P
I have 3 Servo programms and if i push the button he must go to the next program.
const int motorPin = 9;
const int buttonPin = 2;
int buttonState = 0;
int lastButtonState = 0;
int buttonPushCounter = 0;
pinMode(motorPin, OUTPUT);
pinMode(buttonPin, INPUT);
buttonState = digitalRead(buttonPin);
if(buttonState != lastButtonState)
if (buttonState == HIGH){
buttonPushCounter++;
switch (buttonPushCounter)
case 1:
Serial.println("1");
motorOnThenOff();
delay(15);
case 2:
Serial.println("2");
motorAcceleration();
delay(15);
case 3:
Serial.println("3");
motorOnThenOffWithSpeed();
delay(15);
void motorOnThenOff(){
int onTime = 2500;
int offTime = 1000;
digitalWrite(motorPin, HIGH);
delay(onTime);
digitalWrite(motorPin, LOW);
delay(offTime);
void motorOnThenOffWithSpeed(){
int onSpeed = 200;
int onTime = 2500;
int offSpeed = 0;
int offTime = 1000;
analogWrite(motorPin, onSpeed);
delay(onTime);
analogWrite(motorPin, offSpeed);
delay(offTime);
void motorAcceleration(){
int delayTime = 50;
for(int i = 0; i < 256; i++){
analogWrite(motorPin, i);
delay(delayTime);
for(int i = 255; i >= 0; i--){
delay(delayTime);
Go back and modify that post. Select the code and hit the # icon and then save it.
If nothing helps than you have not tried everything have you?
You are doing nothing with the variable lastButtonState, it is never changed!
lastButtonState = buttonState;
case 1:
motorOnThenOff();
delay(15);
case 2:
delay(15);
case 3:
delay(15);
int onTime = 2500;
int offTime = 1000;
delay(onTime);
delay(offTime);
int onSpeed = 200;
int onTime = 2500;
int offSpeed = 0;
int offTime = 1000;
delay(onTime);
delay(offTime);
int delayTime = 50;
delay(delayTime);
delay(delayTime);
Now i add this line: LastbuttonState = Buttonstate
but now he does only do case 1 once and stops then. Why?
Sorry for my bad english i know its bad:p
A google forum search for servo button which may have info of interest from previous post.
http://www.google.com/search?q=servo+button+site%3Ahttp%3A%2F%2Farduino.cc%2Fforum%2Findex.php&hl=en&num=100&lr=&ft=i&cr=&safe=images
Each time you push the switch, buttonPushCounter is incremented. It starts at 0, so the first switch press increments it to 1 and the code for case 1 is executed. Since the code is only executed when the switch is pressed, and buttonPushCounter is incremented before that happens, buttonPushCounter will only be 1 once. So, case 1 will only be executed once.
Do you want the switch statement outside of the if-switch-is-pressed block?
