Arduino Shield and Board Basic Webserver test not working
So I uploaded the basic webserver sketch after not being able to get a OSC sketch to work at all and I cant even get that to work.
i changed the port to see if that would help, it didnt. and i know the IP is in the right range because the router is 192.168.1.1 and my computer is xxx.xxx.x.2 and such.
is there any potential issues concerning the fact the NC shield pin is touching the circular metal thing labeled e0 47 25v (i believe thats a capacitor)
http://www.radioshack.com/product/index.jsp?productId=42635926 - this is the ethernet shield im using
im super frustrated as it seems super simple to get working and there is a good amount of support, so im thinking its a dud seeeduino shield, or just an issue with pin contact. or im an idiot… there is that.
Arduino R2 SMD & Seeduino Ethernet Shield with Wiznet 5200 ver 2 is what I am using for hardware.
Here is my code
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
  • Ethernet shield attached to pins 10, 11, 12, 13
  • Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println(“new client”);
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you’ve gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == ‘\n’ && currentLineIsBlank) {
// send a standard http response header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println(“Connection: close”); // the connection will be closed after completion of the response
client.println(“Refresh: 5”); // refresh the page automatically every 5 sec
client.println();
client.println("");
client.println("");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print(“analog input “);
client.print(analogChannel);
client.print(” is “);
client.print(sensorReading);
client.println(”
client.println(””);
if (c == ‘\n’) {
// you’re starting a new line
else if (c != ‘\r’) {
// you’ve gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println(“client disonnected”);
So i managed to get the shield to receive an IP by connecting my arduino directly to my mac with a Cat5 cable (not a crossover) but i set the IP of my computer manually to 192.168.1.2 and left the subnet mask blank. i then set the arduino to 192.168.10 and then in the serial window it printed that server is at 178.7.20.32
if i try and go to that in a chrome browser it doesnt work, and either does 192.168.1.10, but at least i know the shield isnt a dud now.
I also pinged it from the terminal and got no packet loss so it does exist, i just cant see it, probably due to the absence of a crossover cable
ping -c1 178.7.20.32 PING 178.7.20.32 (178.7.20.32): 56 data bytes 64 bytes from 178.7.20.32: icmp_seq=0 ttl=42 time=161.216 ms
--- 178.7.20.32 ping statistics --- 1 packets transmitted, 1 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 161.216/161.216/161.216/0.000 ms
Client test code you can try to see if you get a response from the server.
edit: possible more info
https://www.google.com/search?as_q=w5200&as_epq=&as_oq=&as_eq=&as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=http%3A%2F%2Fforum.arduino.cc%2Findex&as_occt=any&safe=images&tbs=&as_filetype=&as_rights=&gws_rd=ssl
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
//remove SD card if inserted
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.1"); //download text
    client.println("Host: web.comporium.net");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
So it seems something weird is happening with this shield. I connected it to the WiFi router, and i figured i would try pinging the weird IP that showed up when the arduino was connected to my computer, and wouldnt you know it, i got a response, but when i tried to visit that IP it wouldnt let me.
so i figured out the issue. i needed a different library specifically for the W5200 ethernet shield provided by Seeed. However this presents a problem as the ArdOSC library is not compatible with that.....
