Arduino Shutting Down Right After Plugging
My issue here is that my Arduino Uno shuts down right after plugging it in. I have DHT11, an i2c LCD display, and a 2 channel relay plugged into it. Connected to the channel relay is a heat pad. I have already read that the possible solution for this is to add an external power supply. How do I add an external power supply and specifically, what battery voltage should I use?
I've been using the 5V pin and connected it to a breadboard, then all of the components are connected to it.
Here's the photo of my set-up:
Also, when I remove the relay, the arduino switches on again.
Hi, @nuggexts
Thanks for the pictures.
Do you have a DMM? (Digital MultiMeter)
What are the specs/data for the heat pad?
Where is the power for the heat pad coming from?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
This is the best I can do for a diagram:
Yes, I do have a digital multimeter
Heat Pad Specs:
Cable length: 1.1m
Power consumption. 18W
Voltage: 220V
Frequency: 50Hz
The source of power of the heat pad is from a extension wire connected in a house power outlet.
I forgot to mention, I am also planning to add a HX711 and a 1kg load cell
Also, the relay along with the heat pad can work properly alone. It's just that it switches off with everything connected.
Your relay is at this moment powered from the Arduino. You will need a separate 5V supply and remove JD-VCC. See below image (taken from Relay module effecting Arduino).
Hi, @nuggexts
It will be so much easier to understand, especially if you LABEL pins and components.
If you leave the mains to the heater disconnected, does the fault occur?
Thanks.. Tom... :smiley: :+1: :coffee: :coffee: :australia:
Do the schematic from what I can see you have shorted a lot of things out. Here is some simple guidellines: Gil's Crispy Critter Rules, they apply to processor hardware:
Rule #1. A Power Supply the Arduino is NOT!
Rule #2. Never Connect Anything Inductive (motor, speaker) to an Arduino!
Rule #3 Don't connecting or disconnecting wires with power on.
Rule #4 Do not apply power to any pin unless you know what you are doing.
LaryD's Corollary's
Coro #1 when first starting out, add a 220R resistor in series with both Input and Output pins.
Coro #2 buy a DMM (Digital Multi-meter) to measure voltages, currents and resistance. Violating these rules tends to make crispy critters out of Arduinos.
Hint: It is best to keep the wires under 25cm/10" for good performance.
Thanks! In what mAh should I use?
Sorry, I uploaded the wrong image
The heater can work as long as it's the only one connected to the Arduino. But, when the DHT11 and the LED display was connected along it, it becomes faulty.
It's about mA, not mAh. You can measure the coil resistance; divide Vcc (5V in case of the Uno) by the coil resistance and you will have the peak current. If you cater for that it will be sufficient.
If you power from e.g. USB, mAh does not come into play. If you use a battery, mAh comes into play. You will have to think "I want this to work for "X hours"; multiply the required current calculated above by the hours and you will have the required mAh rating of the battery.
