Arduino si resetta ogni tre cicli
Buongiorno, ho un problema con questo codice:
#include <arduinoUtils.h>
#include "arduinoLoRa.h"
#include <SPI.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
float InterceptDO = -0.33;
float SlopeDO = 3.27;
int e;
char message1[60];
char temp[10];
char lat1[] = "\nLAT: ";
char lon1[] = "\t LON: ";
char data[] = "Dissolved Oxygen: ";
char* buffer1;
char* buffer2;
byte precision = 2;
int count = 0;
TinyGPS gps;
SoftwareSerial ss(2, 3);
bool newData = false;
float flat, flon;
  ss.begin(9600);
  // Power ON the module
  sx1272.ON();
  // Set transmission mode and print the result
  e = sx1272.setMode(1);
  Serial.println(F("Setting Mode: state "));
  Serial.println(e, DEC);
  // Select frequency channel
  e = sx1272.setChannel(CH_13_868);
  Serial.println(F("Setting Channel: state "));
  // Select output power (Max, High or Low)
  e = sx1272.setPower('M');
  Serial.println(F("Setting Power: state "));
  // Set the node address and print the result
  e = sx1272.setNodeAddress(2);
  Serial.println(F("Setting node address: state "));
  // Print a success message
  Serial.println(F("SX1272 successfully configured"));
void loop(void)
  // GPS
  // For one second we parse GPS data and report some key values
  for (unsigned long start = millis(); millis() - start < 1000;)
    while (ss.available())
      char c = ss.read();
      // Serial.write(c); // uncomment this line if you want to see the GPS data flowing
      if (gps.encode(c)) // Did a new valid sentence come in?
        newData = true;
  if (newData)
    unsigned long age;
    gps.f_get_position(&flat, &flon, &age);
    flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat;
    flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon;
  // DO PROBE
  float CountDO = analogRead(A0);
  float VoltageDO = CountDO / 1023 * 5.0;// convert from count to raw voltage
  float SensorReadingDO= InterceptDO + VoltageDO * SlopeDO; //converts voltage to sensor reading
  // LORA
  // dati ossigeno
  dtostrf(SensorReadingDO, precision+1, precision, temp);
  buffer1 = concat(data, temp);
  // latitudine
  dtostrf(flat, precision+1, precision+4, temp);
  buffer2 = concat(lat1, temp);
  buffer1 = concat(buffer1, buffer2);
  // longitudine
  dtostrf(flon, precision+1, precision+4, temp);
  buffer2 = concat(lon1, temp);
  sprintf(message1, buffer1);
  //INVIO
  e = sx1272.sendPacketTimeout(3, message1);
  Serial.println(message1);
  Serial.print(F("Packet sent, state "));
  delete buffer1;
  delete buffer2;
  count++;
  Serial.println(count);
  delay(5000);
char* concat(const char *s1, const char *s2)
    char *result = malloc(strlen(s1)+strlen(s2)+1);//+1 for the zero-terminator
    //in real code you would check for errors in malloc here
    strcpy(result, s1);
    strcat(result, s2);
    return result;
L'arduino esegue tre loop (tre invii di pacchetti), poi si resetta, mentre a volte ne esegue quattro e crasha o inizia a dare problemi con i messaggi inviati (che vengono stampati anche su seriale per testarlo).
Cosa potrebbe essere il problema? Sto usando un Waspmote SX1272 per inviare i dati, quindi sono obbligato a inviare char* e a convertire i float in char*....
Grazie in anticipo,
Simone Garuglieri
Dove definisci la grandezza del buffer1 e buffer2 o meglio dire lo spazio per il suo contenuto?
Ciao Uwe
