Arduino signal converter
I'm trying to connect an ESC to this drone's board, however, it only accepts brushed motors. I want to know if it's possible to use the Arduino to convert the signal from the mosfets to the signal that the ESC accepts. I created this code below but it didn't work correctly
#include <Servo.h>
#define ESC_PIN 9
Servo esc;
  esc.attach(ESC_PIN,  1000, 2000);
  esc.write(0);
  delay(2000);
  pinMode(A0, INPUT);
  int pwmValue = pulseIn(A0, HIGH);
  pwmValue = constrain(pwmValue, 0, 255);
  int motorSpeed = map(pwmValue, 0, 255, 0, 180);
  esc.write(motorSpeed);
What esc. and what drone board?
Normally no difference between brushless or brushed signal requirements, just servo signal.
Hello ausente0
Welcome to the best Arduino Forum ever :slight_smile:
What does that mean in detail?
This may give you some idea's
