Hi, I found a sketch for the load cell pedal but wish to use a potentiometer for the accelerator can someone help me add a potentiometer to the existing sketch it doesn't need the throttle disabled but I can comment it out. Just finding it really hard to find a sketch that uses both potentiometers and a loadcell I found a forum post on x simulator but doesn't seem to work. I'm a total number and have no clue mostly copied others' code or used chat to make stuff that doesn't work as well as it used to for that kind of thing now. Here's the sketch any help welcome I'm useless
#if 1
__asm volatile ("nop");
#endif
#include "HX711.h"
#include "Joystick.h"
#define DOUT 3
#define CLK 2
#define DOUT2 6
#define CLK2 7
// Setup HX711 boards
HX711 throttleScale;
HX711 brakeScale;
// Create raw variables
float rawThrottle = 0;
float rawBrake = 0;
// Create conversion variables
// Line joining (a,0) to (b, 1023) with gradient m=1023/(b-a) and c=-ma
const float minRawThrottle = 30000;
const float maxRawThrottle = 0.94*1000000;
const float mThrottle = 1023/(maxRawThrottle - minRawThrottle);
const float cThrottle = - mThrottle * minRawThrottle;
const float minRawBrake = 15000;
const float maxRawBrake = 800000;
const float mBrake = 1023/(maxRawBrake - minRawBrake);
const float cBrake = - mBrake * minRawBrake;
// Create output variables
float adjThrottle = 0;
float adjBrake = 0;
// Create Joystick
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID + 1, // Don't use first joystick ID, as this is taken by the steering wheel device.
JOYSTICK_TYPE_MULTI_AXIS, 0, 0, // Button Counts
false, false, false, false, false, false, // Axes Includes
false, true, false, true, false); // Rudder, throttle, accelerator, brake, steering
// Set auto send mode on joystick
const bool testAutoSendMode = true;
// Plotting - Comment line(s) to disable plotting and/or timer counter
//#define PLOT_RAW;
//#define PLOT_ADJ;
//#define PLOT_PER;
//#define TIMER_COUNTER;
// Loop Timer
long lastMillis = 0;
long loops = 0;
// Set Inbuilt LED High During Calibration
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
// Begin connection
#ifdef PLOT_RAW || PLOT_ADJ || PLOT_PER || TIMER_COUNTER
#endif
// Setup first HX711
throttleScale.begin(DOUT, CLK);
throttleScale.set_scale();
throttleScale.tare(); // Set scale to 0
long zero_factor = throttleScale.read_average();
// Setup second HX711
brakeScale.begin(DOUT2, CLK2);
brakeScale.set_scale();
brakeScale.tare(); // Set scale to 0
long zero_factor2 = brakeScale.read_average();
// Set Range Values for Joystick
Joystick.setThrottleRange(0, 1023);
Joystick.setBrakeRange(0, 1023);
// Start joystick connection
Joystick.begin(testAutoSendMode);
// Calibration finished, turn off LED
digitalWrite(LED_BUILTIN, LOW);
/* ------------ Read and set Values ------------ */
// Read load cell values
rawThrottle = throttleScale.get_units();
rawBrake = brakeScale.get_units();
// Convert values
adjThrottle = (mThrottle * rawThrottle) + cThrottle;
adjBrake = (mBrake * rawBrake) + cBrake;
// Write values to joystick
Joystick.set throttle(adjThrottle);
Joystick.setBrake(adjBrake);
/* ------------------ Debugging ----------------- /
// Print to plotter
// Raw Load Cell Values
#ifdef PLOT_RAW
Serial.print(rawThrottle, 1);
Serial.print(", ");
Serial.println(rawBrake, 1);
#endif
// Adjusted values
#ifdef PLOT_ADJ
Serial.print(adjThrottle, 1);
Serial.print(", ");
Serial.println(adjBrake, 1);
#endif
// Percentage Values
#ifdef PLOT_PER
if (adjThrottle > 0) {
Serial.print(100.0adjThrottle/1023.);
Serial.print(0.0);
Serial.print(", ");
if (adjBrake > 0) {
Serial.println(100.0*adjBrake/1023.);
Serial.println(0.0);
#endif
// Timer counter
#ifdef TIMER_COUNTER
long currMillis = millis();
loops++;
if(currMillis - lastMillis > 1000){
Serial.print("Loops last second:");
Serial.println(loops);
lastMillis = currMillis;
loops = 0;
#endif
