arduino sim900 gprs data send to http problem
this is code
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(10, 11);
mySerial.begin(19200); // the GPRS baud rate
//after start up the program, you can using terminal to connect the serial of gprs shield,
//if you input ‘t’ in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
//if input ‘d’ in the terminal, it will execute DialVoiceCall(), etc.
if (Serial.available())
switch(Serial.read())
case ‘s’:
Send2Pachube();
if (mySerial.available())
Serial.write(mySerial.read());
///send2Pachube()///
///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function///
void Send2Pachube()
mySerial.println(“AT+CGATT?”);
ShowSerialData();
mySerial.println(“AT+CSTT=“www.xxxx.comuv.com””);//start task and setting the APN,
ShowSerialData();
mySerial.println(“AT+CIICR”);//bring up wireless connection
delay(3000);
ShowSerialData();
mySerial.println(“AT+CIFSR”);//get local IP adress
delay(2000);
ShowSerialData();
mySerial.println(“AT+CIPSPRT=0”);
delay(3000);
ShowSerialData();
mySerial.println("AT+CIPSTART=“tcp”,“api.pachube.com”,“8081"”);//start up the connection
delay(2000);
ShowSerialData();
mySerial.println(“AT+CIPSEND”);//begin send data to remote server
delay(4000);
ShowSerialData();
String humidity = “1031”;//these 4 line code are imitate the real sensor data, because the demo did’t add other sensor, so using 4 string variable to replace.
String moisture = “1242”;//you can replace these four variable to the real sensor data in your project
mySerial.print("{“method”: “put”,“resource”: “/feeds/703024837/”,“params”");//here is the feed you apply from pachube
ShowSerialData();
mySerial.print(": {},“headers”: {“X-PachubeApiKey”:");//in here, you should replace your pachubeapikey
ShowSerialData();
mySerial.print(" “mDbE0acjjkSqks6wQXBoxWKyE0XPrBR03h1rNfbQMpTOW1jR”},“body”:");
ShowSerialData();
mySerial.print(" {“version”: “1.0.0”,“datastreams”: “);
ShowSerialData();
mySerial.println(”[{“id”: “sensor1”,“current_value”: “” + moisture + “”},");
ShowSerialData();
mySerial.println("{“id”: “sensor2”,“current_value”: “” + humidity +""}]},“token”: “lee”}");
ShowSerialData();
mySerial.println((char)26);//sending
delay(5000);//waitting for reply, important! the time is base on the condition of internet
mySerial.println();
ShowSerialData();
mySerial.println(“AT+CIPCLOSE”);//close the connection
delay(100);
ShowSerialData();
void ShowSerialData()
while(mySerial.available()!=0)
please help i count final out put this code…please help me…what is pachube .com …why code this 1…
this error code
AT+CGATT?
+CGATT: 1
OK
OK
AT+CIICR
OK
AT+CIPSPRT=0
OK
AT+CIPSTART=“tcp”,“api.pachube.com”,“8081”
ERROR
AT+CIPSEND
ERROR
{“method”: “put”,“resource”: “/feeds/703024837/”,“params”: {},“headers”: {“X-PachubeApiKey”: “mDbE0acjjkSqks6wQXBoxWKyE0XPrBR03h1rNfbQMpTOW1jR”},“body”: {“version”: “1.0.0”,“datastreams”: [{“id”: “sensor1”,“current_value”: “1242”},
ERROR
{“id”: “sensor2”,“current_value”: “1031”}]},“token”: “lee”}
AT+CIPCLOSE
ERROR
