Arduino Simple Calculator
Hi, Im having trouble with this simple calculator program witch displays two numbers on the screen ( from -10 to 10) using the potentiometer and the rich shield. I also need to display the numbers and the result on the display of the arduino. For the operations I used “a, s, t, d” to represent them.
The problem is that this calculator only allows me to get int type results, operations such as 1/3 giving 0. Do you have any insight that might help? thx
<#include “Display.h”
int mode = 0 ;
int LastButtonState = HIGH;
float value1;
float value2;
int op;
const int POTENTIOMETER = A0;
const int LED_YELLOW = 7;
const int LED_BLUE = 6;
const int LED_GREEN = 5;
const int LED_RED = 4;
const int BUTTON = 8;
Display.on();
Display.show("----");
pinMode(BUTTON, INPUT_PULLUP);
pinMode(LED_RED, OUTPUT);
pinMode(LED_GREEN, OUTPUT);
pinMode(LED_BLUE, OUTPUT);
pinMode(LED_YELLOW, OUTPUT);
int buttonState;
buttonState = digitalRead (BUTTON);
if (buttonState != LastButtonState) {
if (buttonState == LOW) {
//button pressed
mode ++ ;
LastButtonState = buttonState;
//Read Potentiometer
int val;
val = analogRead(POTENTIOMETER);
if (mode == 0) {
//do nothing, wait for first press button
else if (mode == 1) {
mode = 2;
} else if (mode == 2) {
//input value 1
digitalWrite(LED_BLUE, HIGH);
value1 = map (val, 0, 1023, -10, 10 );
Display.show(value1);
} else if (mode == 3) {
//input operator
op = map (val, 0, 1023, 1, 4 );
if (op == 1) {
Display.show(“a”);
else if (op == 2 ) {
Display.show(“s”);
else if (op == 3) {
Display.show(“t”);
else if (op == 4) {
Display.show(“d”);
} else if (mode == 4) {
//input value 2
value2 = map (val, 0, 1023, -10, 10 );
Display.show(value2);
else if (mode == 5) {
// show result
float result;
if (op == 1) {
result = value1 + value2;
digitalWrite(LED_BLUE, LOW);
digitalWrite(LED_GREEN, HIGH);
result = value1 - value2;
else if (op == 3) {
result = value1 * value2;
else if (op == 4) {
if (value2 != 0 ) {
result = value1 / value2;
else {
Display.show(“Err”);
digitalWrite(LED_RED, HIGH);
Display.show(result);
else if (mode == 6 ) { //change the return to mode 2
//back to value 1
mode = 2;
Maybe float variables?
Please remember to use code tags when posting code.
It looks like the '>' at the end of your code should actually be at the top?
