Hey!
So I just started my adventure with Arduino and I am already having a problem. I am trying to hook up lilypad simple with light sensor and I tried so many codes (which changing the pin number correctly) that I started to give up.
I connected '-' on light sensor to '-' on the board, '+' on the sensor with '+' on the board and S with 9 or 5. nothing worked.
help will be really appreciated.
thank you
This is the Lilipad Simple : http://arduino.cc/en/Main/ArduinoBoardLilyPadSimple
The Arduino Uno is the easiest board to start with.
To get to know Lilipad Simple, perhaps you should first try a few other things.
Can you make the led at pin 13 blink ? Can you make it blink faster and slower ?
Next step is the Serial library. Did you try sending messages to the serial monitor ?
That is essential to test sensors.
Which light sensor do you use ? You can copy a link in your post.
Ok seems I figured it all out.
My current question though is how do I introduce in a code more than one sensor and then indicate that each has a different function.
Let's say Im using temperature sensor and I want to to print in in a serial monitor whether its 'cold' or 'hot' depending on my settings. And then there's also light sensor and I want it to do the same except it's gonna print 'white' or 'black'.
Thanks
commak:
Thanks
Well you would have two variables, say "myTemp" and "myLight". Then you choose two threshold values say 25 for cold/hot and 500 (out of 1023) for white/black. Then you just say:
if (myTemp > 25)
Serial.println("hot");
Serial.println("cold");
...... and similar for myLight.
