Arduino Simulator v1.0
Arduino Simulator is a software solution that can give you a helping hand when you want to start working on this type of micro-controller boards.
The interface of the main window is straightforward and intuitive, as it is divided into two tabs called Code and Wiring, each with its specific functionality.
Arduino Simulator comes with multiple demonstrative sketches that can help beginner users understand the functions and uses supported by this type of micro-controller boards. More precisely, these are as follows: LED Loop, Seven Segment, 4x4 Keypad and Touch Sensor.
No matter which one you select, you get the possibility to copy the code and paste it to a third-party file, if you choose to. You can thoroughly analyze the code lines and run the demonstration with a single mouse click.
Download:
