So, i made the single sided Serial Board(v3) and i try to burn the bootloader using the parallel port programmer ( i am using atmega8), the ide gives the following log:
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA8 is 1E 93 07
***failed;
avrdude: verification error, first mismatch at byte 0x0000
0xca != 0xff
avrdude: verification error; content mismatch
I also noticed that when i plug the ICSP connector the 'L' led lights up even when i have not connected the power, I was wondering if its a problem with my board or something else.
If you look at the schematic you will see that ICSP header is connected to +5, Gnd, Reset, SCK, MOSI, and MISO. Pin 19 is both SCK (the SPI serial data clock) and D13, the Arduino pin with the LED, so when the clock is high the light will be lit.
I have not used a parallel programmer (no parallel port on my MacBook) so I don't know what is causing the error.
ok i tinkered a bit and eventually got it to burn the bootlaoder, now when when i try to upload the blink sketch the following error shows up:
Binary sketch size: 1018 bytes (of a 32256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
It could be the auto-reset isn't working. You did put in the auto-reset jumper, right? Try a manual reset. Hold down the Reset button and release it when the "Binary sketch size" message shows up.
