You should include keyboard shortcuts in the next version of the arduino sketch program.
I would love to be able to upload the sketch to the arduino with one quick tap of the f9 key.
regards,
--rtty
is CTRL-U too long? ![]()
robtillaart:
is CTRL-U too long?
Where did you find that one, is there more of these usefull keyboard shortcuts?
Cheers,
Kari
EDIT. Ok, there it is, in the place I wouldn't look normally, File-menu...
Thank you! Ctrl-U it is!
Just go through the menu's of the IDE they are mentioned after the function like many windows progs.
Here's a little cheat-sheet of useful Arduino keyboard shortcuts: (for Windows)
| Ctrl + R | Verify |
| Ctrl + U | Upload |
| Ctrl + Shift + M | Serial Monitor |
Ctrl - T :o :o :o
Man am I glad I did a search. I was going to ask something similar. Thanks for beating me to it!!!
IDE Shortcuts? Now I'm going to have to start paying attention to the menu keys on my usual programs. I might learn something new. An easier way to do things. Imagine that!!!
I never thought I'd say it about keyboard shortcuts but you guys are my hero!!!! Thanks!
There's an undocumented keyboard shortcut that julyjim discovered:
julyjim:
using " ctrl + { " will move mouse cursor from one bracket ("{ } ") to the corresponding one
Also I should note that it works for any type of bracket, not only curly.
If anyone discovers more undocumented shortcuts please do share.
And one NOT documented anywhere I can find:
Ctrl+D
deletes the current line. You don't have to highlight anything.
I wish there was one like this for Cut. Yes, I know there is Ctrl+X and Ctrl+V but you have to select the entire line to make this happen.
Ctrl+D does not require this and that's what I would like to have a Cut of the whole line function work like. There was one in VB6. Ctrl+Y did it. Cut the entire line, no highlighting needed, then you could paste is somewhere else. Nice shortcut to have for rearranging code.
Mike
There's a new shortcut added in Arduino IDE 1.8.4: ctrl+mouse wheel changes the editor font size.
pert:
THAT will make that version worth downloading. Back in a minute...
MikeyMoMo:
And one NOT documented anywhere I can find:Ctrl+Ddeletes the current line. You don't have to highlight anything.
I wish there was one like this for Cut. Yes, I know there is Ctrl+X and Ctrl+V but you have to select the entire line to make this happen. ~
Mike
Maybe it's to late, but I just saw this thread.
If you press "shift" + "end" you can select the whole line. Then use your regular command and you are done.
Hello,
are there some shortcuts to make the code folding easier? (like fold/unfold this, fold/unfold all)
Here's a shortcut keys for Arduino sketch: (for Windows)
ctrl + N New Sketch
ctrl + O Open existing Sketch
ctrl + S Save Sketch
ctrl + R Compile and verify Sketch
ctrl + T Auto format
ctrl + Z Undo last change
ctrl + shift + Z Redo last change
ctrl + shift + M Open Serial monitor
ctrl + / Comment/Uncomment
ctrl + shift + F Find reference page for for selected code
ctrl + K Open Sketch folder
Ctrl + Enter autocompletes with the last matching variable name:
https://forum.arduino.cc/index.php?topic=599911.msg4522499#msg4522499
