so im trying to upload this sketch to a atmega8 via parallel port without bootloader.
int pins[] = {7,6,5,4,3,2}; // an array of pin numbers
int col_len = 6; // column lenght
// customizable parameter
int timer1 =2; // time between columns
int timer2 = 10; // time between frames
int timer3 = 22; // time between drawings
int frame_len = 5; // frame length
int frame_num = 5; // number of frames
// data corresponding to the image to be displayed
int data[] = {1,1,1,1,1,1, 0,0,1,0,0,0, 0,0,1,0,0,0, 0,0,1,0,0,0, 1,1,1,1,1,1, 1,1,1,1,1,1, 1,0,0,1,0,1, 1,0,0,1,0,1, 1,0,0,1,0,1, 1,0,0,1,0,1, 1,1,1,1,1,1, 0,0,0,0,0,1, 0,0,0,0,0,1, 0,0,0,0,0,1, 0,0,0,0,0,1, 1,1,1,1,1,1, 0,0,0,0,0,1, 0,0,0,0,0,1, 0,0,0,0,0,1, 0,0,0,0,0,1, 0,1,1,1,1,0, 1,0,0,0,0,1, 1,0,0,0,0,1, 1,0,0,0,0,1, 0,1,1,1,1,0};
int i;
for (i = 0; i < col_len; i++)
pinMode(pins[i], OUTPUT); // set each pin as an output
int a,b,c;
// go through all data for all columns in each frame.
for (a = 0; a < frame_num; a++)
for (b = 0; b < frame_len; b++)
for (c = 0; c < col_len; c++)
if (data[a*frame_len*col_len + b*col_len + c] == 0) {digitalWrite(pins[c], LOW);}
else {digitalWrite(pins[c], HIGH);}
delay(timer1);
delay(timer2);
delay(timer3);
i compile the sketch and then i locate and burn the .hex file but it doesnt work, i did get the blink sketch to work though in this way.
can some one please convert this so i can copy paste it into avrstudio then compile it there.
Thanks in advance.
