Hi everyone,
Im making a project and I used arduino UNO and SIM808, so a upload that sketch to arduino:
include <SoftwareSerial.h>
#define pinRX 2
#define pinTX 3
SoftwareSerial VTS(pinRX, pinTX);
const int LED_SIM808 = 7;
const int LED_GSM = 8;
const int LED_DATA = 10;
const int LED_GPS = 9;
const int LED_WIFI = 11;
const int LED_B = 6;
const int LED_OK = 5;
const int LED_V = 4;
const int BUTTON_START = 12;
int buttonState = 0;
char resposta[200];
const char gsm_conection[] = "AT+CSTT=\"zap.vivo.com\",\"vivo\",\"vivo\"";
const char host[] = "api.pushingbox.com";
const char DEVID[] = "/pushingbox?devid=xxx";
const char porta[] = "80";
char latitude[15];
char longitude[15];
char altitude[16];
char data[24];
char satelites[3];
char satelites_uso[3];
char velocidade[10];
char curso[15];
pinMode(LED_SIM808, OUTPUT);
pinMode(LED_GSM, OUTPUT);
pinMode(LED_DATA, OUTPUT);
pinMode(LED_GPS, OUTPUT);
pinMode(LED_WIFI, OUTPUT);
pinMode(LED_B, OUTPUT);
pinMode(LED_OK, OUTPUT);
pinMode(LED_V, OUTPUT);
pinMode(BUTTON_START, INPUT);
wait_button();
#ifdef DEBUG_ON
#endif
808.begin(9600);
start_system();
delay(2000);
if (get_http())
blink_led(LED_OK);
blink_led(LED_V);
void wait_button()
buttonState = digitalRead(BUTTON_START);
while (buttonState == 0)
digitalWrite(LED_V, HIGH);
delay(250);
digitalWrite(LED_V, LOW);
delay(250);
// asm volatile (" jmp 0");
void start_system()
blink_led(LED_SIM808);
while (!sendATcommand("AT", "OK", 1000))
blink_led(LED_V);
digitalWrite(LED_SIM808, HIGH);
apn_conection();
while (!data_test());
blink_led(LED_GPS);
while (!sendATcommand("AT+CGNSPWR=1", "OK", 2000))
blink_led(LED_V);
int gps_ok = 0;
for (int i = 0; i < 150; i++)
digitalWrite(LED_GPS, HIGH);
delay(100);
digitalWrite(LED_GPS, LOW);
delay(100);
while(!gps_ok)
if (sendATcommand("AT+CGPSSTATUS?", "3D Fix", 5000))
blink_led(LED_OK);
gps_ok = 1;
else if (sendATcommand("AT+CGPSSTATUS?", "2D Fix", 5000))
blink_led(LED_B);
gps_ok = 1;
blink_led(LED_V);
get_http();
int apn_conection()
blink_led(LED_GSM);
if (!sendATcommand("AT+CIFSR", "ERROR", 5000))
sendATcommand("AT+CIPCLOSE", "ERROR", 2000);
sendATcommand("AT+CIPSERVER=0", "ERROR", 2000);
digitalWrite(LED_GSM, HIGH);
return 1;
sendATcommand("AT+CIPSHUT", "SHUT OK", 3000);
if (sendATcommand(gsm_conection, "OK", 5000))
sendATcommand("AT+CIICR", "OK", 3000);
return 1;
if (data_test())
return 1;
return 0;
int data_test()
blink_led(LED_DATA);
808.print("AT+CIPSTART=\"TCP\",\"");
808.print(host);
808.print("\",\"");
808.print(porta);
808.print("\"");
if (sendATcommand("", "OK", 10000))
blink_led(LED_OK);
blink_led(LED_V);
return 0;
delay(5000);
if (sendATcommand("AT+CIPSEND", ">", 2000))
blink_led(LED_OK);
char end_c[2];
end_c[0] = 0x1a;
end_c[1] = '\0';
808.print(end_c);
808.print("\n\n");
sendATcommand("AT+CIPCLOSE", "CLOSED", 2000);
blink_led(LED_V);
return 0;
808.print("GET ");
808.print(DEVID);
808.print(" HTTP/1.0\nHost: ");
808.print(host);
808.print("\nUser - Agent: Arduino");
if (sendATcommand("", "SEND OK", 5000))
digitalWrite(LED_DATA, HIGH);
return 1;
return 0;
int8_t get_GPS() {
int8_t answer;
char * auxChar;
// request Basic string
sendATcommand("AT+CGNSINF", "O", 2000);
auxChar = strstr(resposta, "+CGNSINF:");
if (auxChar != NULL)
// Limpando as variaveis
memset(longitude, '\0', 15);
memset(latitude, '\0', 15);
memset(altitude, '\0', 16);
memset(data, '\0', 24);
memset(satelites, '\0', 3);
memset(satelites_uso, '\0', 3);
memset(velocidade, '\0', 10);
memset(curso, '\0', 15);
strcpy(resposta, auxChar);
strtok(resposta, ",");
strtok(NULL, ",");
strcpy(data, strtok(NULL, ",")); // Gets date
strcpy(latitude, strtok(NULL, ",")); // Gets latitude
strcpy(longitude, strtok(NULL, ",")); // Gets longitude
strcpy(altitude, strtok(NULL, ",")); // Gets altitude
strcpy(velocidade, strtok(NULL, ",")); // Gets speed over ground. Unit is knots.
strcpy(curso, strtok(NULL, ",")); // Gets course
strtok(NULL, ",");
strtok(NULL, ",");
strtok(NULL, ",");
strtok(NULL, ",");
strcpy(satelites, strtok(NULL, ",")); // Gets satellites
strcpy(satelites_uso, strtok(NULL, ",")); // Gets satellites
answer = 1;
answer = 0;
return answer;
int get_http()
808.print(host);
808.print("\",\"");
808.print(porta);
808.print("\"");
if (!sendATcommand("", "OK", 10000))
return 0;
delay(3000);
if (!get_GPS())
return 0;
if (!sendATcommand("AT+CIPSEND", ">", 2000))
return 0;
808.print("GET /pushingbox?devid=XXXC&lat=");
808.print(latitude);
808.print("&long=");
808.print(longitude);
808.print("&alt=");
808.print(altitude);
808.print("&curso=");
808.print(curso);
808.print("&sat=");
808.print(satelites);
808.print("&satuso=");
808.print(satelites_uso);
808.print("&vel=");
808.print(velocidade);
808.print(host);
if (!sendATcommand("", "SEND OK", 5000))
return 0;
return 1;
void blink_led(int led)
for (int i = 0; i < 3; i++)
digitalWrite(led, HIGH);
delay(125);
digitalWrite(led, LOW);
delay(125);
int8_t sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout) {
uint8_t x = 0, answer = 0;
unsigned long previous;
char readVar[200];
char * auxChar;
char end_c[2];
end_c[0] = 0x1a;
end_c[1] = '\0';
memset(resposta, '\0', 200); // Initialize the string
memset(readVar, '\0', 200); // Initialize the string
while (808.available() > 0) 808.read(); // Clean the input buffer
while (Serial.available() > 0) Serial.read(); // Clean the input buffer
808.write(ATcommand); // Send the AT command
808.write("\r\n\r\n"); // Send enter
808.print(end_c);
#ifdef DEBUG_ON
Serial.println(ATcommand);
#endif
x = 0;
previous = millis();
// this loop waits for the answer
do {
if (808.available() != 0) {
readVar[x] = 808.read();
x++;
// check if the desired answer is in the response of the module
auxChar = strstr(readVar, expected_answer1);
if (strstr(readVar, "+CGNSINF:") == NULL)
strcpy(resposta, readVar);
answer = 1;
// Waits for the asnwer with time out
} while ((answer == 0) && ((millis() - previous) < timeout));
if (auxChar == NULL)
#ifdef DEBUG_ON
Serial.println(readVar);
#endif
return answer;
Until here thats OK on USB works perfectly but when i remove de usb and conect a 12DC 2A, for supply the 808 and arduino the code doesnt works... For works i have to turn on the system and push the reset button from arduino... I have no ideia what can be... Why i have to push reset one time to work?
