sorry, below is the full code - thanks!
int high_rate = 100; int low_rate = 0;
int start_waitTime = 50;
int waitTime = 0;
int reward_time = 300;
#include "pitches.h"
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
int curr_trial = 1;
int last_trial = 1;
const int analog_left = A0;
const int analog_right = A2;
const int digital_center = 8;
int val_left = 0;
int val_right = 0;
int val_center = 0;
int repeat_flag = 0;
int num_repeat = 0;
String to_print = "";
unsigned long trial_start;
unsigned long current_time;
unsigned long currStart;
unsigned long startTime;
volatile unsigned long elapsedTime;
volatile boolean pokeIn;
int play_flag = 0;
int clicks_flag = 0;
int timestep = 1;
int duration = 300;
int left_rate = 0; int right_rate = 0;
int left_click[100] = {}; int right_click[100] = {};
int click_numL = 0; int click_numR = 0;
int curr_leftclick = 1; int curr_rightclick = 1;
Adafruit_8x8matrix matrix_left = Adafruit_8x8matrix();
Adafruit_8x8matrix matrix_center = Adafruit_8x8matrix();
Adafruit_8x8matrix matrix_right = Adafruit_8x8matrix();
matrix_left.begin(0x72); matrix_left.clear(); matrix_left.fillRect(1, 1, 6, 6, LED_OFF); matrix_left.writeDisplay();
matrix_center.begin(0x70); matrix_center.clear(); matrix_center.fillRect(1, 1, 6, 6, LED_OFF); matrix_center.writeDisplay();
matrix_right.begin(0x71); matrix_right.clear(); matrix_right.fillRect(1, 1, 6, 6, LED_OFF); matrix_right.writeDisplay();
pinMode(digital_center, INPUT);
pinMode(6, OUTPUT);
pinMode(13, OUTPUT);
attachInterrupt (0, portWait, CHANGE);
randomSeed(analogRead(5));
generate_clicks();
waitTime = start_waitTime;
trial_start = millis();
if (pokeIn) {
to_print = (String)"wait interval|" + waitTime; Serial.println(to_print);
currStart = startTime / 1000;
matrix_center.clear(); matrix_center.fillRect(1, 1, 6, 6, LED_ON); matrix_center.writeDisplay();
switch (curr_trial) {
case 1:
to_print = (String)"left trial|" + millis(); Serial.println(to_print);
case 2:
to_print = (String)"right trial|" + millis(); Serial.println(to_print);
return;
while (pokeIn) {
current_time = millis();
if ((int)(current_time - currStart) > (waitTime - duration)) {
if ((curr_leftclick < duration * 2) || (curr_rightclick < duration * 2)) {
if (current_time - currStart - (waitTime - duration) > left_click[curr_leftclick]) {
tone(12, 37, 15);
if (left_click[curr_leftclick + 1] > 0) {
curr_leftclick = curr_leftclick + 1;
Serial.println("left");
else {
curr_leftclick = 10000;
else if (current_time - currStart - (waitTime - duration) > right_click[curr_rightclick]) {
tone(5, 37, 15);
if (right_click[curr_rightclick + 1] > 0) {
curr_rightclick = curr_rightclick + 1;
Serial.println("right");
else {
curr_rightclick = 10000;
Serial.println(elapsedTime);
if (elapsedTime < waitTime) {
Serial.println("early exit|");
tone(12, 80, 1000);
tone(5, 80, 1000);
tone(12, 80, 200);
tone(5, 80, 200);
curr_leftclick = 1;
delay(1500);
else {
val_left = analogRead(analog_left); val_right = analogRead(analog_right);
while ((val_left > 500) && (val_right > 500)) {
case 1:
if (val_right < 500) {
tone(5, 70, 500);
to_print = (String)"left error|" + millis(); Serial.println(to_print);
delay(1500);
if (val_left < 500) {
to_print = (String)"correct left|" + millis(); Serial.println(to_print);
digitalWrite(6, LOW); digitalWrite(13, HIGH); delay(reward_time); digitalWrite(6, LOW); digitalWrite(13, LOW);
waitTime = waitTime + 1;
duration = duration + 1;
to_print = (String)"wait time|" + waitTime; Serial.println(to_print);
case 2:
tone(12, 70, 500);
to_print = (String)"right error|" + millis(); Serial.println(to_print);
delay(1500);
to_print = (String)"correct right|" + millis(); Serial.println(to_print);
digitalWrite(6, HIGH); digitalWrite(13, LOW); delay(reward_time); digitalWrite(6, LOW); digitalWrite(13, LOW);
curr_leftclick = 1; curr_rightclick = 1;
generate_trial();
generate_clicks();
play_flag = 0;
void generate_trial() {
last_trial = curr_trial;
curr_trial = random(1, 3);
if (curr_trial == last_trial) {
num_repeat = num_repeat + 1;
if (num_repeat >= 3) {
num_repeat = 0;
if (curr_trial == 1) {
curr_trial = 2;
else {
curr_trial = 1;
Serial.println("trials generated");
void generate_clicks() {
left_rate = high_rate; right_rate = low_rate;
else {
left_rate = low_rate; right_rate = high_rate;
for (int ind = 0; ind < duration; ind++) {
if (left_rate > random(1, 1000)) {
left_click[click_numL] = ind;
click_numL = click_numL + 1;
if (right_rate > random(1, 1000)) {
right_click[click_numR] = ind;
click_numR = click_numR + 1;
for (int ind = click_numL + 1; ind < 100; ind++) {
left_click[ind] = 0;
for (int ind = click_numR + 1; ind < 100; ind++) {
right_click[ind] = 0;
click_numL = 0; click_numR = 0;
clicks_flag = 1;
void portWait () {
if (digitalRead (2) == LOW) {
startTime = micros ();
pokeIn = true;
else {
elapsedTime = (micros () - startTime) / 1000;
pokeIn = false;
