Arduino Sleep Code Question!
Hey Everyone, I am trying to implement a low power code for my arduino mini pro 8 GHz.
I’ve been looking at the example code below:
 * Sketch for testing sleep mode with wake up on timer.
 * Donal Morrissey - 2011.
#include <avr/sleep.h>
#include <avr/power.h>
#define LED_PIN (13)
volatile int f_timer=0;
 *  Name:        ISR(TIMER1_OVF_vect)
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Timer1 Overflow interrupt.
  /* set the flag. */
   if(f_timer == 0)
     f_timer = 1;
 *  Name:        enterSleep
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Enters the arduino into sleep mode.
void enterSleep(void)
  set_sleep_mode(SLEEP_MODE_IDLE);
  sleep_enable();
  /* Disable all of the unused peripherals. This will reduce power
   * consumption further and, more importantly, some of these
   * peripherals may generate interrupts that will wake our Arduino from
   * sleep!
  power_adc_disable();
  power_spi_disable();
  power_timer0_disable();
  power_timer2_disable();
  power_twi_disable();
  /* Now enter sleep mode. */
  sleep_mode();
  /* The program will continue from here after the timer timeout*/
  sleep_disable(); /* First thing to do is disable sleep. */
  /* Re-enable the peripherals. */
  power_all_enable();
 *  Name:        setup
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Setup for the serial comms and the
 *                timer.
  /*** Configure the timer.***/
  /* Normal timer operation.*/
  TCCR1A = 0x00;
  /* Clear the timer counter register.
   * You can pre-load this register with a value in order to
   * reduce the timeout period, say if you wanted to wake up
   * ever 4.0 seconds exactly.
  TCNT1=0x0000;
  /* Configure the prescaler for 1:1024, giving us a
   * timeout of 4.09 seconds.
  TCCR1B = 0x05;
  /* Enable the timer overlow interrupt. */
  TIMSK1=0x01;
 *  Name:        enterSleep
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Main application loop.
  if(f_timer==1)
    f_timer = 0;
    /* Toggle the LED */
    digitalWrite(LED_PIN, !digitalRead(LED_PIN));
    /* Re-enter sleep mode. */
    enterSleep();
basically what I am confused about is…
  1. Why we care about having the f_timer variable? It seems like it is used only to see if the interrupt actually happened.
  2. When I try, instead
 *  Returns:     Nothing.
 *  Parameters:  None.
  /* set the flag. */
   if(f_timer == 0)
     f_timer = 1;
 *  Name:        enterSleep
 *  Returns:     Nothing.
 *  Parameters:  None.
  digitalWrite(LED_PIN, LOW);
  sleep_enable();
   * sleep!
  sleep_mode();
  power_all_enable();
  digitalWrite(LED_PIN, HIGH);
  //delay(100);
 *  Name:        setup
 *  Returns:     Nothing.
 *  Parameters:  None.
 *                timer.
  TCCR1A = 0x00;
  TCNT1=0x0000;
  TCCR1B = 0x04;
  TIMSK1=0x01;
 *  Name:        enterSleep
 *  Returns:     Nothing.
 *  Parameters:  None.
    enterSleep();
I dont see the LEd blinking at all? And when I try replacing the LED indicator with serial.println it just seems like the code doesn’t stay in the “sleep” mode very long at all.
So my question is, is the sleep code in this case actually working? My goal is to have an internal interrupt that wakes the system from sleep and executes a few lines of code around every 300 ms.
  1. Even if this all works, should I be turning off the interrupt after it happens ONCE in between sleeps?
Sorry for the long post!!
anjianwu:
Your Arduino Mini seems to run 1000 times as fast as mine! :slight_smile:
Yes it looks like it is there to record that the interrupt happened.
You haven't set LED_PIN to be an output.
The reason for using sleep code is to reduce the current used. So, with an amp meter, check the current draw. You will need to increase the sleep time for this test from 300 ms, to about 5 seconds to get a good reading.
I did a similar test last week with my leonardo. My amps went from 40ma, down to 9ma during sleep, and back and forth ever 5 seconds.
