Hi there!
So I am trying to make my arduino sleep, and wake up on Serial msgs using the examples provided from : Arduino, Zigbee and Embedded Development: Sleeping Arduino - Part 2 Wake Up Via An External Interrupt
But what I have done differently is placed the sleep_mode() call inside of a infinite loop.(See code below). The idea with this is just to make arduino go back to sleep immediately after it wakes up after the 8s watchdog timer event.
So the example code worked without my adding the loop but with it, the interrupt never fires/wakes up arduino.
// This variable is made volatile because it is changed inside an interrupt function
volatile int sleep_count = 0; // Keep track of how many sleep cycles have been completed.
int sleepInterval = 5; // Interval in minutes between waking and doing tasks.
int sleep_total = (sleepInterval*60)/8; // Approximate number of sleep cycles needed before the interval defined above elapses. Not that this does integer math.
// NOTE WHEN sleepInterval gets eventually changed later also have to recalc sleep total
int pin2 = 2;
//WatchDog Timer Initialization
MCUSR &= ~(1<<WDRF); // clear reset flag
WDTCSR |= (1<<WDCE) | (1<<WDE); // set WDCE to allow updates to prescaler and WDE for 4 clock cycles
WDTCSR = 1<<WDP0 | 1<<WDP3; // set watchdog timer prescale values for max timeout (8 seconds)
WDTCSR |= _BV(WDIE); // enable watchdog interrupts
/* Setup the pin direction. */
pinMode(pin2, INPUT);
if (sleep_count >= sleep_total) {
// CODE TO BE EXECUTED PERIODICALLY
Serial.println("Im awake!");
delay(100);
sleep_count = 0;
enableSleepMode();
Watchdog Interrupt Service. This is executed when watchdog timed out.
ISR(WDT_vect){
sleep_count++; // keep track of how many sleep cycles have been completed.
void pin2Interrupt(void)
/* This will bring us back from sleep. */
/* We detach the interrupt to stop it from
* continuously firing while the interrupt pin
* is low.
detachInterrupt(0);
Serial.println("WHAT? YOU WOKE ME UP!");
* Enables sleep mode by powering down peripherals, etc. Minimizes current draw and power consumption.
void enableSleepMode(void){
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
/* Setup pin2 as an interrupt and attach handler. */
attachInterrupt(0, pin2Interrupt, LOW);
while(true){
sleep_mode();
// program wakes up here from sleep here
sleep_disable();
