I need to put Arduino to sleep between counting pulses.
If I detect pulse on pin X I need to wake up Arduino and increase integer counter.
But pulses may come about 10 times each minute or only one per 24 hours. It is to different.
So I need to wake up Arduino each minute (60s) and send counter status over 433MHz radio.
I found this tutorial Gammon Forum : Electronics : Microprocessors : Power saving techniques for microprocessors
There is example for time watchdog:
#include <avr/sleep.h>
#include <avr/wdt.h>
const byte LED = 9;
// watchdog interrupt
ISR (WDT_vect)
wdt_disable(); // disable watchdog
} // end of WDT_vect
void setup () { }
void loop ()
pinMode (LED, OUTPUT);
digitalWrite (LED, HIGH);
delay (50);
digitalWrite (LED, LOW);
pinMode (LED, INPUT);
// disable ADC
ADCSRA = 0;
// clear various "reset" flags
MCUSR = 0;
// allow changes, disable reset
WDTCSR = bit (WDCE) | bit (WDE);
// set interrupt mode and an interval
WDTCSR = bit (WDIE) | bit (WDP2) | bit (WDP1); // set WDIE, and 1 second delay
wdt_reset(); // pat the dog
set_sleep_mode (SLEEP_MODE_PWR_DOWN);
noInterrupts (); // timed sequence follows
sleep_enable();
// turn off brown-out enable in software
MCUCR = bit (BODS) | bit (BODSE);
MCUCR = bit (BODS);
interrupts (); // guarantees next instruction executed
sleep_cpu ();
// cancel sleep as a precaution
sleep_disable();
} // end of loop
and for pin interrupt:
const byte LED = 9;
void wake ()
sleep_disable();
// precautionary while we do other stuff
detachInterrupt (0);
} // end of wake
void setup ()
digitalWrite (2, HIGH); // enable pull-up
} // end of setup
void loop ()
delay (50);
delay (50);
// disable ADC
ADCSRA = 0;
sleep_enable();
// Do not interrupt before we go to sleep, or the
// ISR will detach interrupts and we won't wake.
noInterrupts ();
// will be called when pin D2 goes low
attachInterrupt (0, wake, FALLING);
EIFR = bit (INTF0); // clear flag for interrupt 0
// BODS must be set to one and BODSE must be set to zero within four clock cycles
// The BODS bit is automatically cleared after three clock cycles
MCUCR = bit (BODS);
// We are guaranteed that the sleep_cpu call will be done
// as the processor executes the next instruction after
// interrupts are turned on.
interrupts (); // one cycle
sleep_cpu (); // one cycle
} // end of loop
How can I combine these two example into one?
ATmega328 has max wake interval 8s in datasheet. How can I sleep for 60s? Is it possible or i must use 56s?
