Hi a7
Being a novice to programing I found your comments a somewhat condescending and not helpful. and by the way the system here does not allow new users to upload attachments
The reason I joined this forum was to learn and get help if I get stuck or share some experience if possible.
I had already reviewed the info from http://www.gammon.com.au that you mentioned before posting here and really attempted for a few day to use his code and intergrade it with mine. Was unsuccessful hence my post here
My sketch is simply using a touch sensor to activate a servo motor from initial 0 to 180 then back to 0. then I want the Adruino NANO to go to sleep to conserve some battery life.
so if anyone can help intergrade the gammon's sketch below into mine it would be greatly appreciated. As I'm out of ideas.
- Author:Ab Kurk
- version: 1.0
- date: 24/01/2018
- Description:
- This sketch is part of the beginners guide to putting your Arduino to sleep
- tutorial. It is to demonstrate how to put your arduino into deep sleep and
- how to wake it up.
- Link To Tutorial Tutorial:A guide to putting your Arduino to sleep — The Arduino Maker Man
#include <avr/sleep.h>//this AVR library contains the methods that controls the sleep modes
#define interruptPin 2 //Pin we are going to use to wake up the Arduino
Serial.begin(115200);//Start Serial Comunication
pinMode(LED_BUILTIN,OUTPUT);//We use the led on pin 13 to indecate when Arduino is A sleep
pinMode(interruptPin,INPUT_PULLUP);//Set pin d2 to input using the buildin pullup resistor
digitalWrite(LED_BUILTIN,HIGH);//turning LED on
delay(5000);//wait 5 seconds before going to sleep
Going_To_Sleep();
void Going_To_Sleep(){
sleep_enable();//Enabling sleep mode
attachInterrupt(0, wakeUp, LOW);//attaching a interrupt to pin d2
set_sleep_mode(SLEEP_MODE_PWR_DOWN);//Setting the sleep mode, in our case full sleep
digitalWrite(LED_BUILTIN,LOW);//turning LED off
delay(1000); //wait a second to allow the led to be turned off before going to sleep
sleep_cpu();//activating sleep mode
Serial.println("just woke up!");//next line of code executed after the interrupt
void wakeUp(){
Serial.println("Interrrupt Fired");//Print message to serial monitor
sleep_disable();//Disable sleep mode
detachInterrupt(0); //Removes the interrupt from pin 2;
my sketch
#include <Servo.h>
// constants won't change
const int SENSOR = 2; // Arduino pin connected to motion sensor's pin 7
const int SERVO = 9; // Arduino pin connected to servo motor's pin 9
Servo servo; // create servo object to control a servo
int pos = 0; // variable to store the servo position
// variables will change:
int lastMotionState; // the previous state of motion sensor
int currentMotionState; // the current state of motion sensor
Serial.begin(9600); // initialize serial
pinMode(SENSOR, INPUT); // set arduino pin 9 to input mode
servo.attach(SERVO); // attaches the servo on pin 12 to the servo object
servo.write(0);
currentMotionState = digitalRead(SENSOR);
lastMotionState = currentMotionState; // save the last state
currentMotionState = digitalRead(SENSOR); // read new state
if (currentMotionState == LOW && lastMotionState == HIGH) { // pin state change: LOW -> HIGH
Serial.println("OFF");
servo.write(0);
delay(100); // waits (X)ms for the servo to reach the position
if (currentMotionState == HIGH && lastMotionState == LOW) { // pin state change: HIGH -> LOW
Serial.println("ACTIVE");
servo.write(180);
delay(2000); // waits (x)ms for the servo to reach the position
delay(10); // repeats program - larger delay - trigger is
