Good day all,
Is it possible for a Arduino Mega to slow down as you add more code?
I've got a Mega, with a 8 way relay board, 3.2 inch TFT(Non Touch) and a 4x4 keypad with a code which controls the on/off times of the relays as well as outputs some variables onto the screen.
I'm still trying to make the keypad work so that I can change the off time of the relay, but at the moment it seems like the timings of the relays, as well as the keypad push responses have really slowed down quite a bit.
The code which I have so far is as follow (I created a tab for each section, so apologies for the separate codes in the thread.
#include <UTFT.h>
#include <Keypad.h>
UTFT myGLCD(CTE32HR, 38, 39, 40, 41);
extern uint8_t BigFont[];
extern uint8_t Grotesk32x64[];
const byte Machine1 = A0; // I/O pin connected by the first relay
const byte Machine2 = A1;
const byte Machine3 = A2;
const byte Machine4 = A3;
const byte Machine5 = A4;
const byte Machine6 = A5;
const byte Machine7 = A6;
const byte Machine8 = A7;
unsigned long BlowerStartTime;
unsigned long BlowerStopTime;
bool BlowerIsRunning = false;
byte CurrentBlower = Machine1;
int onTime = 1 ; // seconds on
int offTime = 100 ; // seconds off
byte numbr[4]; // This will hold 4 bytes, and if global, will init to all zeros
byte indx; //This will hold an index to the array. If global, it will init to 0
int enteredValue; // this will hold the final value entered
int currentMenuItem = 0;
int lastState = 0;
int a = 4;
unsigned int blows = 0;
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Four columns
char keys[ROWS][COLS] =
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {2, 3, 4, 5};
byte colPins[COLS] = {6, 7, 8, 9};
Keypad kpd = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS );
for (int i = Machine1; i <= Machine8; i += 1)
pinMode(i, OUTPUT); //set digital I/O pin as output
myGLCD.InitLCD();
myGLCD.setFont(Grotesk32x64);
myGLCD.clrScr();
myGLCD.setColor(VGA_BLUE);
myGLCD.print("CHINCO FIRESIDE", CENTER, 100);
myGLCD.print("TREATMENT", CENTER, 164);
delay (3000);
myGLCD.clrScr();
title();
ManageBlowers();
keyPad();
void ManageBlowers() {
if (BlowerIsRunning)
if (millis() - BlowerStartTime > onTime * 1000UL)
StopBlower(CurrentBlower);
CurrentBlower += 1;
if (CurrentBlower > Machine8)
if (millis() - BlowerStopTime > offTime * 1000UL)
StartBlower(CurrentBlower);
void StopBlower(int BlowerPin)
digitalWrite(BlowerPin, LOW);
BlowerStopTime = millis();
void StartBlower(int BlowerPin)
digitalWrite(BlowerPin, HIGH);
blows ++;
BlowerIsRunning = true;
BlowerStartTime = millis();
void keyPad() {
char key = kpd.getKey();
char key1 = kpd.getKey();
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
// Check for a valid key
if (key)
// set the cursor to column 9, line 1
//(note: line 1 is the second row, since counting begins with 0):
//lcd.setCursor(9, 1);
//Print the detected key
myGLCD.setColor(VGA_RED);
myGLCD.printNumI(key - 48, 207, 228);
delay (5);
myGLCD.printNumI(key1 - 48, 223, 228);
delay (5);
void title() {
int activeDays = millis() / 864000000UL;
int activeHours = millis() / 3600000UL;
int powderUsed = (blows * 50) / 1000;
myGLCD.drawRect(0, 0, 479, 305);
myGLCD.setColor(VGA_WHITE);
myGLCD.setFont(BigFont);
myGLCD.print("CHINCO FIRESIDE TREATMENT", CENTER, 2);
myGLCD.print("Delay Between Blows :", 2, 48); // Delay time
myGLCD.printNumI(offTime, 337, 48);
myGLCD.print("s", 403, 48);
myGLCD.print("Duration of Each Blow :", 2, 64); // Blow time
myGLCD.printNumI(onTime, 368, 64);
myGLCD.print("s", 402, 64);
myGLCD.print("System Active For :", 2, 80); //Active Days
myGLCD.printNumI(activeDays, 305, 80);
myGLCD.print("Days", 355, 80);
myGLCD.print("System Active For :", 2, 96); //Active Hours
myGLCD.printNumI(activeHours, 305, 96);
myGLCD.print("Hours", 355, 96);
myGLCD.print("Number of Blows :", 2, 112); //Blows
myGLCD.printNumI(blows, 274 , 112);
myGLCD.print("KGs powder used :", 2, 128); //KGs used
myGLCD.printNumI(powderUsed, 274, 128);
myGLCD.print("Serial # 0001", RIGHT, 286); // Change on each new timer
myGLCD.print("CHANGE BLOW DELAY TIME", CENTER, 194);
myGLCD.print("ENTER VALUE", CENTER, 210);
myGLCD.print("PRESS # TO SAVE", CENTER, 248);
