Arduino - Smart Wifi Robot Car
I've reviewed the forum and followed instructions and I still can not get the program to upload.
I tried on Windows 10 and Windows 7
Arduino 1.8.8
One Item I'm not clear on is if I have the right Programmer (Tools > Programmer) or if I need to Burn Bootloader (Tools > Burn Bootloader)
By default the Programmer is AVRISP mkll
I tried different examples but the one I want to upload is WIFI_Camera_Robot_Car
Here is the compile log from Windows 7
any help would be appreciated
Arduino: 1.8.8 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 13994 bytes (43%) of program storage space. Maximum is 32256 bytes.
Global variables use 695 bytes (33%) of dynamic memory, leaving 1353 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\Abitz\AppData\Local\Temp\arduino_build_400536/WIFI_Camera_Robot_Car.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb5
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
The 'burn bootloader' option requires a programmer. Do you use one?
If you don't have one and you have a second Arduino, you can use that as a programmer. See https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard. In step 3, you need to select the correct target board.
Merry Christmas.
PS
I've never used the Arduini as ISP; I use a dedicated programmer.
