I want to run commands Set, Get and Walk from MIB browser.
I have written a code, Set and Get are working fine but getting "Timed Out" error while running Walk command from MIB browser.
Can you please help me with my code?
Given code below is the pduReceived() function which is invoked when Set/Get/Walk command is ran from MIB browser.
If you want the full code, please find it attached in this post.
void pduReceived()
SNMP_PDU pdu;
api_status = Agentuino.requestPdu(&pdu);
if ((pdu.type == SNMP_PDU_GET || pdu.type == SNMP_PDU_GET_NEXT || pdu.type == SNMP_PDU_SET) && pdu.error == SNMP_ERR_NO_ERROR && api_status == SNMP_API_STAT_SUCCESS )
pdu.OID.toString(oid);
if ( pdu.type == SNMP_PDU_GET_NEXT )
char tmpOIDfs[SNMP_MAX_OID_LEN];
if ( strcmp_P( oid, sysDescr ) == 0 )
strcpy_P ( oid, sysUpTime );
strcpy_P ( tmpOIDfs, sysUpTime );
pdu.OID.fromString(tmpOIDfs);
else if ( strcmp_P(oid, sysUpTime ) == 0 )
strcpy_P ( oid, sysContact );
strcpy_P ( tmpOIDfs, sysContact );
else if ( strcmp_P(oid, sysContact ) == 0 )
strcpy_P ( oid, sysName );
strcpy_P ( tmpOIDfs, sysName );
else if ( strcmp_P(oid, sysName ) == 0 )
strcpy_P ( oid, sysLocation );
strcpy_P ( tmpOIDfs, sysLocation );
else if ( strcmp_P(oid, sysLocation ) == 0 )
strcpy_P ( oid, sysServices );
strcpy_P ( tmpOIDfs, sysServices );
else if ( strcmp_P(oid, sysServices ) == 0 )
strcpy_P ( oid, RR1 );
strcpy_P ( tmpOIDfs, RR1 );
else if ( strcmp_P(oid, RR1 ) == 0 )
strcpy_P ( oid, RR2 );
strcpy_P ( tmpOIDfs, RR2 );
else if ( strcmp_P(oid, RR2 ) == 0 )
strcpy_P ( oid, RR3 );
strcpy_P ( tmpOIDfs, RR3 );
else if ( strcmp_P(oid, RR3 ) == 0 )
strcpy_P ( oid, RR4 );
strcpy_P ( tmpOIDfs, RR4 );
else if ( strcmp_P(oid, RR4 ) == 0 )
strcpy_P ( oid, "1.0" );
int ilen = strlen(oid);
if ( strncmp_P(oid, sysDescr, ilen ) == 0 )
strcpy_P ( oid, sysDescr );
strcpy_P ( tmpOIDfs, sysDescr );
else if ( strncmp_P(oid, sysUpTime, ilen ) == 0 )
else if ( strncmp_P(oid, sysContact, ilen ) == 0 )
else if ( strncmp_P(oid, sysName, ilen ) == 0 )
else if ( strncmp_P(oid, sysLocation, ilen ) == 0 )
else if ( strncmp_P(oid, sysServices, ilen ) == 0 )
else if ( strncmp_P(oid, RR1, ilen ) == 0 )
else if ( strncmp_P(oid, RR2, ilen ) == 0 )
else if ( strncmp_P(oid, RR3, ilen ) == 0 )
else if ( strncmp_P(oid, RR4, ilen ) == 0 )
// End of implementation SNMP GET NEXT / WALK
if ( strcmp_P(oid, sysDescr ) == 0 )
if ( pdu.type == SNMP_PDU_SET )
status = pdu.VALUE.decode(locDescr, strlen(locDescr));
pdu.type = SNMP_PDU_RESPONSE;
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locDescr);
pdu.error = status;
pdu.error = SNMP_ERR_READ_ONLY;
status = pdu.VALUE.encode(SNMP_SYNTAX_TIME_TICKS, locUpTime);
pdu.error = status;
status = pdu.VALUE.decode(locName, strlen(locName));
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locName);
pdu.error = status;
status = pdu.VALUE.decode(locContact, strlen(locContact));
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locContact);
pdu.error = status;
status = pdu.VALUE.decode(locLocation, strlen(locLocation));
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locLocation);
pdu.error = status;
else if ( strcmp_P(oid, sysServices) == 0 )
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, locServices);
pdu.error = status;
status = pdu.VALUE.decode(relayPointer);
if (status == 0)
relayCommand[0] = *pdu.VALUE.data;
if (relayCommand[0] == 0)
digitalWrite(R1, LOW);
if (relayCommand[0] == 1)
digitalWrite(R1, HIGH);
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, relayCommand[0]);
pdu.error = status;
if (status == 0)
relayCommand[1] = *pdu.VALUE.data;
if (relayCommand[1] == 0)
digitalWrite(R2, LOW);
if (relayCommand[1] == 1)
digitalWrite(R2, HIGH);
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, relayCommand[1]);
pdu.error = status;
if (status == 0)
relayCommand[2] = *pdu.VALUE.data;
if (relayCommand[2] == 0)
digitalWrite(R3, LOW);
if (relayCommand[2] == 1)
digitalWrite(R3, HIGH);
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, relayCommand[2]);
pdu.error = status;
if (status == 0)
relayCommand[3] = *pdu.VALUE.data;
if (relayCommand[3] == 0)
digitalWrite(R4, LOW);
if (relayCommand[3] == 1)
digitalWrite(R4, HIGH);
pdu.error = status;
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, relayCommand[3]);
pdu.error = status;
pdu.error = SNMP_ERR_NO_SUCH_NAME;
Agentuino.responsePdu(&pdu);
Agentuino.freePdu(&pdu);
SNMP_Test_Program.ino (12.3 KB)
